Question about Kenmore Washing Machines
Lost earrings in washer
I have lost a pair of valuable earrings in the washer, they are small enough to fit through the holes. where could they be and how can I find them?
2 Suggested Answers
  • 1028 Answers
SOURCE: Small earrings fell into holes on bottom
if they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Posted on Sep 11, 2008
Lost the tool that came with my Pro tech carbon monoxide alarm to change the battery
I discovered that a pair of pointy-ending tweezers (not the flat ones) worked perfectly. The points fit in the holes, and the tweezers could be squeezed to fit both holes at the same time. Why Protech decided that an ordinary phillips screw was not good enough is the subject of a whole rant...
Nov 06, 2013 | Protech 7035-SL Lithium Powered Carbon...
Husqvarna 266 parts diagram what all do you have to do to replace fuel filter and line on 266 do you have to take saw apart
No need to take the machine apart, there are two types of fuel hose depending on the age of the saw, the early machine has a hose with a moulding in the center to hold it in the tank, the later machine has a thinner spiral hose which is just an interference fit in the tank, to fit the early hose remove the tan cap and empty any fuel, fit the fuel fiter on the end of the hose, useing a pair of long nose pliers grip the other end of the hose, enter it into the tank and feed the end up through the hole in the tank, now grab the end as it comes up by the right hand side of the carb, pull into place so as the moulded grommet fit snug in the tank. To fit the later hose trim one end of the hose so it is easily small enough to fit through the hole in the tank, use the long nose pliers and enter the pipe in through the open filler hole, feed up through the tank, grab the end at the right hand side of the carb and pull on through, trim off the end square and connect to the carb, there will be enough with this hose to pull out through the open filler hole to easily fit the fuel filter.
Sep 29, 2013 | Garden
Are there certain types of metal that should be avoided when buying earrings?
It really depends on the individual. Definitely for your first pair of earrings, you should use gold posts. This means that the actual post part that is in the ear is made of real gold which will reduce the risk of infection.
Once the ear has healed (4-6 weeks) and you are allowed to change your earrings you can begin to experiment. Obviously cheaper metals are more likely to cause irritation and infection but some people have an allergic reaction to the good quality jewelry so it's a bit of trial and error.
Feb 20, 2013 | Health & Beauty
I just got my ears pierced and I was told to use alcohol every day to clean the holes but my friend said I also have to twist the earrings. Is that true?
Your friend actually gave you some good advice. The alcohol twice a day on the ear is a way of preventing infection in the new holes. Twisting the new earrings around every day several times will help keep movement and stop the earrings from sticking. It will also help the holes to be a good size and not close up. It sounds a bit scary but it shouldn't hurt at all. Good luck.
I lost one earring recently
mcdevito75 here, You say you lost an earring, I think you mean part of your watch band, if so, look for a small watch repair shop in your area.
Feb 11, 2011 | Watches
What is behind the round plate on the right front, bottom of my washer and how do i remove it?
Hi, That is the access panel for the washer drain pump button trap/lint filter as well as the emergency door release. To open it you will need a small screwdriver a drill bit or anything small enough to fit in the small hole you'll see in this panel. Once you've located the hole, apply a little pressure inward ( theres a lock tab there ) and turn it clockwise and it should come right off. Once off be careful, the edges are extremely sharp. Hope that answers your question. If so please rate it accordingly, if not let me know how I can assist you further. Thank's for visiting "fixya" for your solution and good luck. Macmarkus :)
Apr 03, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer not draining - foul smell
It is so nice to get positive feedback from the people we work so diligently to help. Thank you, thank you, thank you!! And enjoy those earrings!!
Jul 15, 2009 | GE WSXH208A Front Load Washer
Pairing a bluetooth adapter without key
hay the key is nothing more then a metal stylus try using a sewing pin in place of the stylus. it is metal and small enough to fit in the hole this will alow you to press the button and set it into pairing mode. good luck and have a nice day!
Feb 08, 2009 | Cardo BTA II - Cellular phone Bluetooth...
HOW DO I TAKE A LINK OUT OF THE WATCH BAND
I found a pushpin small enough to fit down into the hole and was able to push out the pin in the band far enough to get a hold of it with a pair of pliers and pull it out. Repman was right, they are in very tight and it takes some "elbow grease" to get them out.
Dec 25, 2008 | Watches
Sep 11, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
