Question about Cameras
GE Profile GSP40 cooktop hot burner indicator wont light up
Glass cook top, hot burner indicator is not lighting up. Will flash if there is pressure applied to the cook top.
  • Ceri Howell Jan 22, 2013
    This is not a digital camera it is a stove?? Sorry have no idea how to fix it...
    Genius:
  • Cameras Master
  • 1,669 Answers
This is obviously a loose connection in the panel that is flexed when you put pressure on the top. The rear panel needs to be opened and checked.
Posted on Jan 22, 2013
    Thanks! any links to sights that would have more info? We are very new to trying to fix appliances
  • Leigh Perlmutter
    Leigh Perlmutter Jan 22, 2013
    It does require some skill. Especially when it comes to working with electricity. Pulling apart a stove is not something I recommend as a novice job. Get a professional electrician or appliance repair service.
The burner indicator light on my GE profile glass cook top stays on when the stove is turned off. Any thoughts?
mine does the same thing, in my case it is just indicating the burner is still hot after being turned off.. it goes off after awhile, which is normal.
Oct 09, 2010 | Kitchen Ranges
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
GE Profile JB 968 Hot Cooktop Indicator Light Always On
Temporary solution to turn off the indicator lamp - put a wet rag with an ice pack on top on the middle section of the cooktop.
The thermal sensor will trip off the lamp.
Jan 03, 2009 | GE Profile JB968 Electric Kitchen Range
Hot burner indicator light won't shut off
the switch for the bottom right burner is bad but doent not affect the cooking, just the light
Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
