Question about ATI RADEON X1650 Graphic Card
Can i run ati radeon HD3650 512mb on asus k8N motherboard
Dear sir
1)I have an other question,can i run ati radeon HD3650 512mb on Asus K8N board.i have got 512mb ram 1.8 gh processor amd athlon 2800+.
2) I cannot understand that,may u tell me, link between DDR2 agp and DDR ram,can i run DDR3 agp card on my board while i am using DDR 512mb on my motherboard.what the difference i am confused on this matter.
thanks
Tabish
  • 68 Answers
Firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Posted on Jan 27, 2009
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
How to downlode driver asus mother board k8n-vm ?
Hi, try this link for your drivers:
http://www.driverstock.com/ASUS-K8N-VM-driver-download/6-9-10112/index.html
Aug 13, 2010 | ASUS K8N-VM Motherboard
ASUS K8N MB On board audio doesn't work. I've verified that correct settings in BIOS but signal is not making it to the plug for Line Out. I just installed SP2 so I'm going after new drivers next. Any...
Check FP_AUDIO pin settings. FP_AUDIO is located just below the CD AUX. See page 1-6, Motherboard layout.
There should be a jumper over pins 9 and 10 and pins 5 and 6. This is the default setting chassis rear MB audio output.
See page 1-22.
Unfortunately the audio chip is soldered to the motherboard. Most newer Asus MBs the audio chip is not soldered and can be replaced by calling Asus.
Asus manual; http://dlsvr04.asus.com/pub/ASUS/mb/sock754/K8N/e1868_k8n.pdf
Link to Asus site, K8N; http://www.asus.com/product.aspx?P_ID=zigzffr75jWJ7j2y&templete=2
A possible work around would be to disiable the AC'97 in the bios and add a PCI audio card.
Cheers'
Mike
Feb 04, 2010 | ASUS K8N Motherboard
you can upgrade your processor to a 3200+ or a 3600+ but the problem is availability and it should be socket 754 pin compatible...
regarding the HD3650 card...as long as its aa AGP card you should not have any problems..
also check your SMPS (power supply) it should be atleast 350(V)..
Jan 28, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
ASUS K8N-VM mother board win98 drives
Try going to the Asus website and look for support for your MB drivers and Operating System.
If there is no longer any Win98 support for your MB then I suggest a fresh computer and more recent software for less hassle!
A ten year old OS indicates to me that you might be stuck until you go with the flow!
Cruel but true.
Hopefully the recent cheap prices for computers pre-installed with Vista or XP will persuade you.
Feb 06, 2008 | ASUS K8N-VM Motherboard
Asus K8N-dl - second processor present but not running...
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
Aug 04, 2007 | ASUS K8N-DL Motherboard
ATI RADEON X1650 Graphic Card Logo
216 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
