Question about Denon AVR-2106 Receiver
Radio won't work on my Denon Receiver
My radio on my Denon receiver is not working. All the other components connected to the receiver work fine. When i turn the radio on it won't lock into a channel. When i auto scan for a channel it just keeps going around and won't pick up any channel. it is almost like the antennae isn't working or picking up any signal. Does anyone know how to fix this or whether it is even worth fixing?
  • Craig Ekstrom Jul 23, 2007
    I tried using wire and it still doesn't work. Even in mono mode i can't pick up any channels. Any other advice?
  • 147 Answers
Hook up a Small piece of wire Coming off the #00 ohm input for ant also put it in Mono mode first and you should be able to Hear Hiss Then tune Let me Know ttech
Posted on Jul 20, 2007
SOURCE:
I am using a Denon internet radio on LAN (pirelli modem), works fine, but I cannot receive BBC. BBC on the PC works fine. Could that be a router problem? Any ports or adjustments I have to consider? If so,...
I have the same problems with my Pirelli modem in Austria (A1) trying to play BBC radio stations. I connected my Denon CEOL RCD-N7 to a different network (SilverServer in Austria) and it played the BBC radio stations swimmingly (not sure what modem was used btw)... I have another internet radio at home (Reciva based) and surprisingly, that one plays the BBC stations fine using the WMA streams.
I do have a workaround now for the Denon system: I have added the following URLs (AAC streams) to "My Added Stations" on RadioDenon.com and they work like a charm:
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r2_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r3_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4x_aaclca.pls
Any suggestions as to what the issue might be with the Pirelli modem are welcome!
-- Hope this helps.
Jan 29, 2013 | Denon Audio Players & Recorders
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Intermittent low hum in TV/cbl mode works fine in tunner DVD mod
I switched out of the audio-out cables from the cable box to the audio in at the Denon receiver and went with a coaxial cable connection. That switch got rid of the hum. I don't understand why the initial connection produced the hum, but the unit is working fine now.
Jan 28, 2009 | Denon AVR-1908
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
Denon AVR-2106 Receiver Logo
350 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
