Question about Evga nForce 680i SLI 775 TR (122-CK-NF68-TR) Motherboard
System not powering up. Orange light coming on on evga 680i
I had a toasted power supply, which I have replaces. All connectors are now getting juice. When I connect the power cable, my evga 680i mobo blue light turns on, as is expected. When I press the POWER button on the case, I hear a VERY brief little squeak or peep... like a VERY short (less than one second) whining beep and an orange/amber light on the mobo comes on (near the blue light).
I pulled all but one DIMM of memory in the first black slot (as the mobo guide suggests), no change.
Any thoughts?
Scott
MOTHERBOARD: EVGA NForce 680i SLI 122-CK-NF68-AR
I am unsure of the proper voltage for the Memory, so I have been hesitant to change voltages from AUTO in my BIOS. I am willing to sdo it and take the risk is someone knowledgable tells me the proper value.
THANK YOU FOR THE HELP!
Scott
In the end, maybe a snip from Belarc advisor will help.
Operating System
Windows Vista Ultimate (x64) Service Pack 1 (build 6001)
System Model
EVGA 122-CK-NF68 2
System Serial Number: 1
Enclosure Type: Desktop
Processor a
2.67 gigahertz Intel Core2 Quad 64 kilobyte primary memory cache 4096 kilobyte secondary memory cache
Main Circuit Board b
Board: EVGA 122-CK-NF68 2
Serial Number: 1
Bus Clock: 267 megahertz
BIOS: Phoenix Technologies, LTD 6.00 PG 09/04/2008
Drives
600.13 Gigabytes Usable Hard Drive Capacity
460.05 Gigabytes Hard Drive Free Space
Memorex DVD16+/-DL4RWlD2 ATA Device [CD-ROM drive]
VQRMZU XYRG1IZ SCSI CdRom Device [CD-ROM drive]
  • Scott Adams
    Scott Adams Jan 28, 2009
    Riaz -- You basically said: Check everything. I appreciate the thought, but I need more guidance than that.
  • Scott Adams
    Scott Adams Feb 03, 2009
    For anyone who ever looks, it was a faulty power supply. The chip wasn't getting any juice, but everything else was.
Check your hardsik or memory or other wise out your motherborad and download in check card your problem will be ko
im riaz ahmed brohi or email riazbrohi@gmail.com
Posted on Jan 27, 2009
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
Have an EVGA nForce 680i. Bought 2x 2 GB 6400 800Mhz of ram to replace 2x 1 GB sticks. However when I start up the system it only reads that I have 2874 MB of RAM. So I figured maybe one of the sticks is...
Hi.
The reason its only seeing just under 3GB of memory is no doubt because you are using a 32BIT operating system (probably XP).
If you were to install Win 7 (X32) or a 64BIT operating system the computer would see all 4GB of RAM you have installed.
Its nothing to worry about though as the computer will work just fine. If you were to check in the BIOS you would see all 4GB of memory is there and see by the BIOS.
Regards.
May 01, 2011 | Evga nForce 680i SLI (122CKNF68)...
Xbox 360 is flashing orange light does not work at all....
your power supply is toasted just buy a new one but before go to a videogame store (eb games or microplay) to test your console with an other power supply to verify if your xbox have toasted with your power supply
Jun 22, 2009 | Video Game Consoles & Games
Power supply not working?
To see if power supply works
unplug the psu from the motherboard and drives
then plug the power cord into psu and wall
the fan should come on letting you know that it works.
you can also get a multimeter and check each individual connector on the 20/24 pin connector to motherboard.
check the psu docs for the correct voltages to each pin
If you smelled smoke then chances are that something may have gotten toasted.
remove all expansion cards and try to turn on computer if nothing happens then the motherboard may have gotten toasted.
Check the motherboard and expansion cards along with memory for shorts and burn spots.
A+ Technician
Apr 02, 2009 | HP HEC HP485D 485W ORION HP485D ATX 12V...
Please help me to solve no display evga 680i sli (- -)error code
hi im josh in cebu phils.may i help you? friend try my solution ; Problem: Your Monitor Works, but Displays an Error Message Before Windows Loads If you see an error message, you at least know that video signals are getting to your monitor. Look for these common messages:
Bad or missing FILENAME In this message, the FILENAME refers to your video card's device driver file. Make sure that the driver has been copied to your hard disk and selected properly within Windows.
NUMBERxx This type of message (such as 24xx) indicates that you have a defective video card or a problem on the motherboard, or that you are trying to display in a mode that your system can't display. Check all the switch settings on your card and motherboard, and if the problem persists, see a repair technician. try to use that, good luck hope i helped you.
Mar 04, 2009 | Evga nForce 680i SLI (122CKNF68)...
Computer not turning on
open core voltage connection after if that power on
so problem in your motherboard vrm circuit goes off
Jan 17, 2009 | Evga nForce 680i SLI (122CKNF68)...
Computer will not turn on. it is just "sparking" ie fans/lights/come on for split second and then everything goes off. on my evga motherboard there is a FF display. i have been troubleshooting easy things...
Not sure about the FF. If everything comes on and then powers off after only a split second, there is not time for the display to show anything. I'm suspecting it is indicating there is no signal.
The very first thing I would try on this computer is the power supply (assuming it's a desktop system).
A faulty power supply can act like this.
Evga 680i motherboard no signal on monitor
Nice Mobo by the way. Are you using Vista or XP? Does the board POST?Do you use the SLI feature?Does the bios hand off to Windows? If you can answer these questions it would help. I have more questions but I would like to start with these
Nov 28, 2008 | Evga nForce 680i SLI (122CKNF68)...
EVGA motherboard not turning on...
Your motherboards is getting heated, there might be a manufacturing defect in the board, if there is a warranty claim it.
Dec 06, 2007 | Evga (122-CK-NF68-T1) Motherboard
Evga nForce 680i SLI 775 TR (122-CK-NF68-TR) Motherboard Logo
1,306 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
