How to set LCD PANASONIC Th-32LX80-32 inch
Lcd tv
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
I need a firmware for Panasonic TH-L32C20X LCD TV, Software Version: 1140 Can you help me, Thanks.
sounds like you need a technician but try the panason website and support you will need a pc and sd card
http://av.jpn.support.panasonic.com/support/global/cs/tv/download/fw/europe/step3_eu.html
Dec 17, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Panasonic 32-inch LCD TV Blinking 3 Times. Not Turning On. Please Help.
http://www.tv-forums.com/forum/TV_Equipment_C4/LCD_TV_Forum_F41/Panasonic_lcd_Tc-32lx60l_with_blinking_stby_light._P151410/
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the APh
Jul 19, 2015 | Panasonic Televison & Video
Suport format mpeg4,flv,..
Please never do any more experiments with software [firmware] with this set. Contact the authorized service centre for Panasonic. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Panasonic TH-L42U20S Full HD 42 inch...
TH-L32C20X does not read hdmi cable
is the driver installed on the computer you are using at the minute?
Feb 12, 2013 | Panasonic TH-L32C20X 32 inch Multi-System...
Need User Manual for Panasonic Viera TH-L37X10S Lcd tv
The manual for theTH-L37X10S is available from Panasonic here: http://www.panasonic.ae/EN/Manuals/TH-L37X10A.pdf . (Note it's the same manual even though the final letter is different.) If the above link doesn't work, start here: http://www.panasonic.ae/EN/Pages/TH-L37X10.aspx and click on the Manuals tab.
I hope this helps.
Sep 12, 2012 | Panasonic VIERA TH-L37X10S MULTISYSTEM HD...
Iwant to buy of main board panasonic viera
Contact the nearest authorised service center for Panasonic to buy an original one.
Jun 09, 2012 | Panasonic TH-L32C20X 32 inch Multi-System...
What should be the picture settings for panasonic th-l32c22 lcd tv
i have a panasonic th-l32c22 lcd tv which is full hd and it is connected with ip tv .so please tell me that (What should be the good hd picture settings forpanasonic th-l32c22)
Oct 17, 2010 | Televison & Video
Panasonic 50 inch lcd
This may be a screen addressing fault, or a driver fault, possible bad ribbon cable, cold solder connection in the screen drive or processor, or the screen itself may be faulty.
The set would have to be properly diagnosed to know the exact failure, and the necessary parts changed.
Jerry G.
Mar 28, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
