Question about Xerox Phaser 7750DN Laser Printer
Can't get my 7750dn to connect to my network
I bought a used 7750dn and can't get it to connect to my network. When I use DHCP/BOOTP server and Auto IP, the printer selects the ip address 168.254.160.83 which is outside my Routers DHCP range. Also not getting any solid lights from the ethernet port. I've also tried manually entering the ip address, but it's still not appearing on the network. Help would be greatly appreciated. Thanks
  • fixya967 Jan 27, 2009
    I've downloaded and used the instructions & have the "auto IP" & "DHCP/BOOTP" set to manual, but still no luck
    Guru:
  • 110 Answers
Maybe you should try a diffrent image control board if available. Also make sure you cleared out the NVRAM because if you have the old IP address from the owner before you it won't work. Call this company that does almost only xerox printers services. www.Iteminc.com is their website I don't know their number but man they got good techs. Hopes this helps and good luck :)
Posted on Mar 16, 2009
    President:
  • 2,072 Answers
I am not sure why I can't copy and paste the instructions.
You can go to Xerox.com, then click on support and drivers. In the search box type in 7750 then go to the troubleshooting area and type in the search sett up IP and the instructions will be there.
I am sorry, I have tries numerious times to past and send it on here but for some reason it wil not send.
Be sure though, when you get into the network settings, set the DHCP to Manual or static, which ever it says. Don't leave it on Auto,change it to Manual and that way the address will not change.
Posted on Jan 27, 2009
  • Rick Kasper Jan 27, 2009
    Call 1-800-821-2797 and ask for second level support.
    There is something small not happening.
    Can you ping the printer? If you can ping it and the network is not faulting out, the machine should be fine. Those network boards are really finicky if there are problems on them.
    I have never seen one not accept an IP address. That machine has a very stable network board and hard drive.
Does the SR505n modem have a BOOTP mode? how to set it to BOOTP so a DHCP server assigns the IP (not the default 192.168.1.1)?
I am not quite sure what you mean by a "BOOTP" mode for this modem, but the following link takes you to a downloadable pdf file which is the manual for this modem and others in the range.
http://www.start.ca/files/smartrg505n.pdf
Among other things it shows how to disable the DHCP server aspect of this modem (around page 29 I think) and gives you all the means of getting into the modem's settings and configuration area.
May 07, 2014 | Computers & Internet
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
IP Address 3200mfp
Dynamic addressing (BOOTP/DHCP)
To have a TCP/IP address assigned automatically by the server, take the
following steps:
1. Press Menu until Network Setup appears on the top line of the display.
2. Press the scroll button ( or ) until "Config Network" appears and press
Enter.
3. Press Enter when "TCP/IP" appears.
4. Press the scroll button ( or ) until "DHCP" or "BOOTP" appears and
press Enter.
5. Press Stop/Clear to return to Standby mode.
Static addressing
To enter a TCP/IP address from your machine's control panel, take the
following steps:
1. Press Menu until "Network Setup" appears on the top line of the display.
Enter.
4. Press Enter when "Manual" appears.
5. Press Enter when "IP Address" appears.
6. Enter a byte between 0 and 255 using the number keypad and press the
scroll button ( or ) to move between bytes.
7. Repeat this to complete the address from the 1st byte to the 4th byte.
8. When you have finished, press Enter.
May 07, 2014 | Office Equipment & Supplies
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
I installed a new router on our small network and now our hp 4600 color laserjet printer shows offline and will not come online no matter what I try.
First, make sure your Router is configured for DHCP, and the Printer is plugged into the Router using a Network Cable. Also, make sure the Activity light on your Router is On for the Port that your plugged the Printer into.
Configuring TCP/IP parameters
You can use the printer control panel to configure the following TCP/IP parameters:
  • usage of the BOOTP file for configuration parameters (the default is to use the BOOTP file)
  • IP address (4 bytes)
  • subnet mask (4 bytes)
  • default gateway (4 bytes)
  • TCP/IP connection timeout (in seconds)
Note: Do not disable BOOTP if you will be using RARP or DHCP to configure TCP/IP parameters.
To automatically configure TCP/IP parameters from the printer control panel:
1. Press the Check Mark button to enter the MENUS.
2. Press the Down Arrow to highlight CONFIGURE DEVICE.
3. Press the Check Mark button to select CONFIGURE DEVICE.
4. Press the Down Arrow to highlight I/O.
5. Press the Check Mark button to select I/O.
6. Press the Down Arrow to highlight EIO X (where X = 1, 2, or 3).
7. Press the Check Mark button to select EIO X.
8. Press the Down Arrow to highlight AUTO.
9. Press the Check Mark button to select AUTO.
10. Press the PAUSE/RESUME button to return to the READY state.
Here is your Manual, with more information about Network Configuration:
http://business.fsu.edu/tech/printermanuals/laserprinters/HP4600.pdf
Jun 18, 2011 | HP Color LaserJet 4600n Printer
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
May 26, 2009 | HP LaserJet 4100dtn Printer
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
What is BOOTP/DHCP?
BOOTP stands for Bootstrap Protocol. DHCP stands for Dynamic Host Configuration Protocol. Both are mechanisms to dynamically assign an IP address for a TCP/IP client by the server. In this case, the Prestige 310 Internet Access Sharing Router is a BOOTP/DHCP server. Win95 and WinNT clients use DHCP to request an internal IP address, while WFW and WinSock clients use BOOTP. TCP/IP clients may specify their own IP or utilize BOOTP/DHCP to request an IP address.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Xerox Phaser 7750DN Laser Printer Logo
161 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
