Question about Flaghouse Eliminator 7 Slate Pool Table With Pockets - W15497 - Game Table
Installation instructions for eliminator slate pool table
What kind of putty do you use to fill in the holes in pool table slate
Best Billiards Online Catalog
Large holes and chips: Kerr-Vel Slate Patch (hard, accurate)
Broken or cracked slate: Slate Repair Glue
Seams: Billiard table wax (harder type of beeswax)
Application of above substances takes some skills.
Pool Table Slate Repair Prepping and Leveling Slate
There are specialized services: http://pooltablemovershouston.net/repair-services/
Nov 21, 2017 | Pool & Spa
Find parts for pool girl
Hi! Those pool toys are actually manufactured a different company. You can get in touch with them at /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman","serif";}
May 01, 2014 | Dirt Devil Pool Vacuums: Pool Girl...
How to install slate roofing
A slate roofing is actually a nice idea because its make your home quite pretty. To use slate roofing first you need better kins of slates its breakable also but now including roofing you should try another options like metal roofing, rolled roofing , its easy then slate roofing you can also visit http://andersonindustrialroofing.net/replacement/
Jan 12, 2013 | Roofing
I want to buy a pool table online what should I do?
You should visit http://www.topofthecue.com it's a very trustworthy site and the deliver their products pretty fast. In the site they got all the accessories needed for a pool table including cues, balls and even chalks and you can also find different types of tables in many prices all depend on the amount of money you want to invest.
Jul 31, 2012 | Sport & Outdoor - Others
What's the standard size of a pool table?
There are three common sizes for billiard tables. 3.5 On 7, 4 on 8 and 4.5 on 9. The table width should be half the size of its overall length. If you watching billiard tournament on TV you probably wonder why the tables look so big, most cases you would be right because in tournaments they use the 9 feet tables and most pool sellers supplies up to 8 feet table.
I Have a Easy Set Pool 15X36, And a Salt Water Generator How much Salt do I add for the first Time?
The Compupool CPSC/CPA Series is recommended to run at a salt concentration of 3500 ppm. If you are not installing a Compupool unit, check your manufacturer's instructions for their recommended level of concentration . Use a salt that is at least 99.8% pure NaCl. The preferred salt is an evaporated, granulated, food quality, NON-iodized salt. Avoid using salt with anti-caking agents like sodium ferrocyanide, also known as yellow YPS (prussiate of soda. These cause some discoloration of fittings and pool surface finishes. DO NOT use calcium chloride.
Using a salt water test strip, measure the current salt level of your pool. For the Compupool generators, ideal is 3500 ppm. If the level is low, determine the number of gallons in your pool and add salt according to the Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
Jun 08, 2011 | Sport & Outdoor - Others
How to dismantle a pool table
Susanna, if this is an 8' professional type pool table with a slate top, you're going to need 2 men and a boy to help you. 90% of the dismantling of parts is done from under the table. Literally, just about everything ( Rails, side panels, legs, etc ) unbolts from underneath. About the only thing that doesn't is the slate top. It may be in two pieces rather than one and it's heavy.
Once you start looking around under the table, you'll see how it all goes together. Except, you'll be taking it apart.
Good luck and hope this helps you dismantle it, safely.
Apr 21, 2011 | Heating & Cooling
Flaghouse Eliminator 7 Slate Pool Table With Pockets - W15497 - Game Table Logo
65 people viewed this question
Top Flaghouse Sport & Outdoor - Others Experts
Bill Eager
Are you a Flaghouse Sport and Outdoor - Other Expert? Answer questions, earn points and help others
