Question about FUJIFILM S2940 Digital Camera
HOW DO I SET THE DUAL IS MODE ON THIS CAMERA
I'm trying to set the "IS" TO DUAL MODE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
Press the MENU/OK button. Press cursor-left, then use cursor-up/down to select the wrench-SET icon. Press cursor-right, use cursor-up/down to select "DUAL IS MODE" and press cursor-right. Use cursor-up/down to select the desired mode then press MENU/OK.
See pages 95-97 in this manual for full details.
Posted on Jan 22, 2013
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Can't get closed captioning to work on westinghouse 46" 4680 led tv
What is the video source? Some set-top boxes send a closed caption signal that doesn't match the TV's CC interpreter. For those devices, you need to enable the captions on the set-top box.
I know how to enable captions on one particular Dish satellite box. The steps will depend on if your TV is TV1 or TV2 connected to the box. If the TV is TV2, you need to set the box in Single mode (so both TVs are set to the same channel). This is done with the Mode button on the box itself (highlight Yes and click Select using the Dish remote when prompted to go to Single Mode). If the box is in Single Mode, you won't get a prompt but the unit will go to Dual mode. There is a small LED on the box to indicate Single or Dual mode.
Next press Menu on the remote and go to Properties (9). Click Select and then navigate to Closed Captions (6). Click Select. Go to the Closed Caption On/Off line (1) and press the left arrow and then the up/down arrow to set to the captions to On. Press the right arrow and then Select with Done highlighted. Exit the Menu by hitting Cancel repeatedly.
I hope this helps.
Jul 24, 2012 | Westinghouse Televison & Video
Dual DRF2810 wont switch on I have a Dual TV, the standby light comes on for a few seconds then goes off and won't switch on. You suggested checking that the 'sleep' mode was not set but h
Click here and try to download the user manual to your device. If it is amde by Dual, the manual must be here. Download it and see whether you have done any wrong adjustment to it.
May 14, 2012 | Televison & Video
MY OLYMPUS DIGITAL CAMERA FE-230 IS OUT OF FOCUS? PICTURES TAKEN ARE ALL BLURRED.
Try one of these tips:
>Hold your camera steady using both hands
>Hold your breath just before you take a hand-held shot
>Use a tripod, or a set your camera on a steady surface
>Set your camera's self-timer
Set the dial mode to auto ;
Turn off macro mode;
Turn on the camera's flash.
At the link below you will be able to download the instruction manual for Olympus FE-230 Digital Camera:
Click HERE
Jul 26, 2011 | Olympus Cameras
There must be something simple I am doing wrong. On a D700 body, I can't seem to trip the shutter in any aperture other than f16.
I have a Nikon D60, and it has numerous settings, including aperture and shutter priority, and others. It sounds like you have have it set in aperture mode, set for f/16. First try taking a picture in dimmer light, where it's not so bright. That should cause the shutter to open longer. The camera will adjust the shutter speed to take the best picture at f/16 if it's set for that.To adjust it to something other than f/16, on my camera, you use the thumb wheel on the back of the camera. Try changing that if it has a thumb wheel.
Next try it in Auto mode by rotating the dial on the top of the camera to the green setting and see if you get a batter picture.
If all else fails, consult the camera manual, if you have one.
Jul 13, 2011 | Nikon 85/1.4 AFD Nikkor Lens
My N70 when im calling is always in 'network busy',while compere to other cellphone they can easily call.pls help me. thanks.
Try to check your network signal if it's stable or dropping,also try to transfer your simcard to other phone and see if the problem is still the same.try check the settings of your network if you are using 3g or dual mode or only gsm mode,sometimes dual mode signal is not consistent by going to settings > phone > network and set it to gsm mode.
another way is formatting or resetting your phone,back up all necessary data first before proceeding,on your home screen type *#7370#, a lock code will be ask.enter the desire code or 12345 as the default code,then it will reboot automatically.Now try the signal if its ok.
If the above method doesn't work,might be a hardware problem and let a mobile service technician fix this problem,so you can find out what particular problem takes place.
Thank you for visiting Fixya,
Jul 12, 2011 | Nokia N70 Cellular Phone
Manual that came with camera does not explain symbols for setting the mode. Amazing! What do M, A,S,P, N and SP 1 and SP2 stand for? the only things I understand are Auto and Panorama.
M stands for 'Manual mode'. This is the mode wherein you set your shutter speed and aperture setting. A stands for 'Aperture Priority'. This is the mode where you set the aperture or opening of the lens and the camera sets the shutter speed. The lower the aperture number setting, the more light penetrates the lens, a faster shutter speed is needed. This setting is usually used for portrait scenarios. S stands for 'Shutter priority'. This is the mode where you set the shutter speed and the camera sets the aperture. The higher shutter speed number, the lower aperture number is set by the camera to accommodate more light into the lens. This setting is usually used for capturing moving objects like cars. P stands for 'Program Mode'. The camera takes care of different settings except for the aperture and the shutter speed. You get to choose combinations of aperture and shutter speed settings that will not change the exposure of your scene. This is like a combined 'A' and 'S' mode with different combinations. N stands for 'Natural Light'. The camera tries to make use of available light. This is ideal for indoor use when flash is prohibited or when you just want to capture the ambiance of the scene. The camera sets a high sensitivity setting to handle low light conditions. The drawback of this would be grainier pictures. SP1 and SP2 stand for Scene Position 1 and 2. This is like a memory setting for most commonly used scene settings. For example, you can assign SP1 for landscape mode scene and SP2 for night mode scene. You have 13 scenes to choose from in your camera, 2 of which you can assign in SP1 or SP2. The default setting for SP1 is Portrait mode and for SP2, it is Landscape mode.
Hope this helps.
Apr 15, 2011 | Fuji FinePix S1000FD Digital Camera
Does this card support dual screen mode? I just bought a monitor that I'd like to use with my HP Pavilion dv6t. I can't set the resolution higher than 1366 x 768. I am told that if the video card must...
Dual screen mode? You mean dual monitor mode?
But anyways, the maximum resolution that you can obtain on your Pavilion dv6t is 1366x768 unless you attach an external monitor. Even then, only the external monitor can go above 1366x768 resolution. You're laptop screen will remain at 1366x768 max.
Ericthecmh
Jul 31, 2010 | HP Pavilion dv6t Notebook
My Fuji s2000 always shoots picture that are blured. I have tried many settings and different exposures however I keep getting the same result. What can I do ? The worst mode on this camera is the auto...
Found the same thing and I think the answer is the opposite of previous suggestions. The s2000 is truly awful at anything above about 400ASA The degree of pixel binning it uses just makes the pictures look terrible. Force the camera to use 400 or slower (lower numbers), force flash and I think you'll see a great difference. I was on the verge of sending mine back before I discovered this.
Ian
Aug 10, 2009 | Fuji FinePix S2000hd Digital Camera
FUJIFILM S2940 Digital Camera Logo
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
