Question about Dryers
It won't let me dry and says "loc"
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Unplug and wait 3 minutes then re plug and start from beginning.
Posted on Jan 22, 2013
It won't spin water out and it's saying loc
What make and model washing machine?
Jul 21, 2013 | Washing Machines
"LOC". As I turn the dial to the requested setting, all the times (15min. 55 min., etc.) are displayed, but as I go to push the 'start' button, the screen says, "LOC",...
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Electric Dryer
My 1989 Jaguar won't start mornings but starts by mid day
check to make sure there is no crack or liquid getting into your distributor cap.
Oct 08, 2012 | 1989 Jaguar XJ6
LG WM3431hs drum won't turn on dry cycle
Broken drive belt tho your model number is not for a dryer.
Feb 04, 2018 | LG WM3431 Front Load Washer / Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Dryer code says "loc" and
Jul 20, 2011 | Frigidaire Electric Dryer
Dryers Logo
Top Dryers Experts
