Furnace wont lite
I can see the ignitor glow red but it wont lite
  • Heating & Co... Master
  • 2,602 Answers
Try jumping out the presure switch and see if it lights , check hoses are not split or blocked
Posted on Jan 23, 2013
  • 2602 Answers
SOURCE: goodman furnace won't ignite. No glow from ignitor.
yes if the ignitor has a very small crack on it it will not work replace it and see if it works but do not touch the end that glows when you put it in as the grease from your finger s will stop it working
Posted on Jan 08, 2009
SRF518
  • 232 Answers
SOURCE: Hear furnace start, ignitor glows but not kicking
the flame rod doesn't come into play until the pilot flame is established. check the pilot valve.
Posted on Oct 23, 2009
  • 117 Answers
SOURCE: goodman furnace ignitor works, blower starts up
sounds more like a pressure switch problem. If the pressure switch does not make, then the furnace will not attempt to light. Its a safety feature on residential furnaces.
Check the pressure switch and hose for obstructions. Clear any and attempt to re-light. If still not successful, its time to contact a local service company to check the gas valves and electronics.
Posted on Apr 27, 2010
richroth
  • 9472 Answers
SOURCE: I have a Goodman GMP
Here is a link to all the information you will need to test and repair your furnace. This should get you up and running in no time.
Happy Holidays! The FixYa Team
Posted on Dec 26, 2010
  • 224 Answers
SOURCE: The furnace will not light. The vent blower is
This is only a suggestion for you as I do not have all the Dayton manuals available. So I would be looking at the pilot assembly and what we are looking for is a thermocouple or possibly a photo electric eye. The click from the gas valve may only be for the pilot to ignite and not the burners yet. If there is a thermocouple try cleaning it with steel wool and positioning it over the top center of the pilot flame, also check where the thermocouple connects to the gas valve and make sure it has a snug connection. Should it be the photo electric eye type of sensor you can try cleaning it off with a soft rag, and make sure it has an unobstructed view of the flame. From what you describe it sounds as if it is not getting signal that a pilot has been established. This is why I am pointing you in this direction.Trace your wiring both to and from the gas valve as there may be other safety sensors in line.Should you run in to one check it with a volt ohm meter and it should register normally closed, if open there you are. Take your time and power down the unit to trouble shoot please.
Posted on Jan 10, 2011
I have a jandy lite 2 pool heater, fl 2 error appears even though flow seems ok burner wont fire. should the pressure switch be replaced.
FL2 means igniton failure that means the heater didnt lite make sure gas is on, is the ignitor glowing if not check the fuse on the red wires going to the ignitor sometimes the syphon loop gets plugged that will give you a flow issue
Sep 01, 2014 | Pool & Spa
My Amana GUI090B30B furnace will not ignite. The ignitor glows then the valve releases gas but the gas does not ignite. The ignitor goes out and the valve shuts after a second or two of trying to ignite...
Hello, it is possible that even tnough the ignitor is glowing it might be too weak to ignite the burners. I would cneck the resistance of the ignitor with a multmeter, should be between 40-90 ohms typically
Nov 28, 2011 | Heating & Cooling
Furnace starts up blower starts..nothing ignites...then shuts down. repeats and doesnt stop...sanded igniter stick and nothing happend. flashes red once.
Do you see the actual ignitor glow? You must be saying that you sanded the sensor. The ignitor, after the little inducer fan comes on will begin to glow a bright orange until the burner lights. If the ignitor is broken, you will NOT see a glow, and you may smell a faint smell of gas.
Apr 14, 2011 | Goodman GMS90703BXA Heater
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
We bought a duplex and it has a Payne furnace from 2007. No paperwork. The lower unit suddenly shut off. The furnace has a blinking red light and now has no heat blowing to it. Is there anything we can...
yes you can unplug furnace for about 20 seconds and replug then start up unit... a common problem with alot of furnaces this time of year is the hot surface ignitor fails which is the glow plug on the unit .. the unit when called for heat should start a small motor with a wheel on it known as the enducer draft motor then activates the round switch with the plastic hose connected to it...make sure the hose is not kinked or obstructed...pull the end off opposite of the round switch if you **** on the hose should here a clicking sound.. reconnect after the switch has closed then the power is sent over to a ignitor on most furnaces some have spark ignition but either way that is the next step after the ignitor glows red hot then the gas valve should open and fire off ..after it lites there is a flame sensor a metal rod that is in the direct path of the flame that measures current and keeps gas valve open once unit reaches temperature a limit will activate the blower to come on....where does it fail ... most units with a led code will have a sticker attached to the door outer or inner door with code meaning... count the flashes and then look for code...hope this helps out
Jan 25, 2011 | Heating & Cooling
Ten yr old Goodman residential furnace won't light even though hot surface ignitor glows red for 1 or 2 seconds.
Make sure you have gas on. Tap on the valve as the ignitor glows. The valve may just be stuck. If not- I'm thinking the funace needs a new ignition module.
Jan 17, 2011 | Heating & Cooling
My furnace wont lite
Problem: Your furnace will not ignite the gas to produce heat for your home.The following is the sequence of operation and probable cause:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch (or circuit breaker ) back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands (use gloves). If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 29, 2010 | Heating & Cooling
HSI ignitor is glowing red but furnace isn't lighting every time
most likely the gas vavle only buy honeywell valve the rest are junk
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
