Question about Maytag MDG16PD Gas Commercial Dryer
Coin operated digital maytag dryer price change
How to set new price
    New Friend:
  • 169 Answers
What brand coin mechanism do you have?
Posted on Jan 22, 2013
  • 177 Answers
SOURCE: Maytag com dryer Model #MDE16PRAYW Setting coin Value
Unplug the unit, open the control panel, look for the instructions inside the control panel. program as needed. you will need access to coin vault and meter case.
Posted on Jun 07, 2008
  • 67 Answers
SOURCE: maytag coin operated dryer
is the dryer heating at all? have u tried it disconnected from the vent to see if it makes any difference, if disconnected and it still doesnt work correctly u'll probably need a new thermostat it also depends on if it gas or electric heating elements in electric are either good or bad no in between its just a coil
Posted on Mar 21, 2007
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
Healeyman
  • 1198 Answers
SOURCE: Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Posted on Apr 22, 2009
Illeagle
  • 525 Answers
SOURCE: commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
Price on new 42"screen
As the screen itself is the most expensive part of the set, it is almost never cost effective to replace it. With the price of sets decreasing each model year, you can get something as big or bigger and probably better (more features) for the same or less money than the replacement would cost you.
Dec 30, 2015 | Televison & Video
My tvs centra 2004 modal bike is not given good milage,2005 to2010 it given 85kml,but now it given 50kml.what price a new carbureter?
Hi,first I dont know the price of a new carb,but why dont you just get new gasket set and new jets for the carb you have,will be much cheeper,just a thought,all the best.
Sep 03, 2015 | TVS Motorcycles
How do I change the price setting on a matag model md630pc2aw
YOU TAKE OUT THE BLANK THAT IS WHERE A COIN SHOULD GO AND THEN YOU PUT IN A QUARTER SLOT PLUG,GO TO SEARS FOR BLANKS.
May 30, 2014 | Maytag MDG16PD Gas Commercial Dryer
Can you program a Da 7p Plus coffee without the handheld programmer?
Saeco 7P+ pricing is set mainly without programer. The machine has 2 pricing points so the price of the beverages can be set to one of the two prices. To change which price point the beverage is assigned to you need to use the programmer. Price point 1 is the lower price and price point 2 is the higher price.
To change the price on all beverages, make sure there is power to the door. On the inside of the door the is a little circuit board with two red buttons. On the bottom side of that board is a little button that is normally black. Press this button and the screen should read 000. If you push up (which is the 1st beverage button) the screen will read 001 this is price point 1. Press enter (4th beverage button) to change the price and use the up and down keys (down is the 2nd button down).
To change price point 2 press cancel (3rd beverage button down) if your in price point 1. If your in the menu at 001 just press up again and the screen will read 002. Repeat steps above to change.
Normally all beverages are set to the same price, if this is the case than change both price points to the same price.
It is better to set price point 2 first as price point 1 won't adjust higher than what price point 2 is set at.
When done which the machine off then back on.
Have fun.
May 10, 2014 | Saeco Coffee Makers & Espresso Machines
How to change the digital maytag dryer coin setting
Bes way is to get instruction manual from manufacture of coin mechanism
Dec 07, 2013 | Maytag Dryers
How to change the price for a digital maytag dryer
Best way is to get help and instruction manual from manufacture of coin mechanism
The screen is broken
It will be best to buy a new TV rather than repair this set by doing a panel replacement. It might cost more than the price of a new one including price of panel plus service charges.
Jun 09, 2012 | Vizio VO47L 47 in. LCD TV
I need a new screen
buy a new set as part needed alone will cost more than the new set will.
Jun 08, 2012 | Sylvania LC370SS9 LCD TV
Maytag MDG16PD Gas Commercial Dryer Logo
192 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
