Question about Fender Deluxe VM Tube Amplifier
Background hiss in fender hot rod deluxe tube amplifier
Is this normal, how loud should it be?
  • 11 Answers
SOURCE: Fender Hot Rod Deluxe making popping noise
Ah yes, the Fender Hot Rod Deluxe. I have seen more of these in my shop than any other amplifier!! I have even sent recomendations for design changes to Fender about this amplifier.
Sadly, your amp tech may be correct: while the amp is within working specs, you can still have an issue with a bad socket. The cheapest thing to try is to replace the preamp tube(s) you think may be causing the problem. If the problem persists, it may need to be serviced on this issue (by a different 'certified Fender tech'). In defense of the last tech you had work on this amp, these amplifiers have a brittle design and do not gig or travel well (there are a minority of these amps made that do perform). Fender tried to do too much for the price on this model: best advice is to fix it, sell it and get your tone with a more stable model made by Fender (like the new vintage re-issues). Fender, like Marshall, has for years been having problems when they get too far from thier 'working reciepe' of what made them great companies.
You likely have a socket that needs re-tensioned, or a preamp tube not behaving. If it is not these, then a tech had to dive in the house of cards that is this circuit. Sorry for the bad news on this, but it is the truth. I only take on Hot Rods that 'appear' to be fixable. I am a development engineer, build amps from scratch and fix them for the local music shops, and my success rate is a dismal 60%-ish percent on these...
Thanks,-mike
Posted on Mar 30, 2009
  • 5603 Answers
SOURCE: I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Posted on Jul 26, 2009
  • 506 Answers
SOURCE: Fender Hot Rod Deluxe. Turns on, sounds very good
More than likely a bad solder joint. Where is the next question. How confident are you with voltage measurments? The rails in tube amps are high and can kill you so if you are not inclined to do so please don't. The reason I suspect a solder joint is that it is a failure over time, cold solder joints expand and contract with heat. When they heat up they break connection. Not saying 100% that is your problem but it is very likley.
Posted on Dec 14, 2009
Testimonial: "Hey thanks for responding!...I am not savy at this so I will take it to an expert before those tuibes blow on my face. Thanks again!"
  • 417 Answers
SOURCE: fender hot rod deluxe tube rattle.
poosibly the tube sockets are not holding the tube in place anymore. Usually the Fender's have a spring loaded carriage so to speak that hold tubes in place.
Posted on Apr 01, 2010
  • 5603 Answers
SOURCE: I have Fender Hot Rod Deluxe and Blues Deluxe
I want you to do a test. while using the amp plug a pair of headphones into the preamp out... note you will only hear stuff on one side if they are stereo phones and the sound may be fairly weak... while the unit is operating correctely then unplug phones and use it. When it fades out plug in phones compare the level when it was OK... If the preamp output fades lower as well, then we know problem is in the preamp section...
We can do a lot of troubleshooting without opening the amp.
I see nothing in the scheamtics that should be an issue causing this...
Since it didn't fail for the tech, think "what was different?". Are you connecting something else? Foot pedal? Temperature? :Loudness of playing?
Now what else is in common to these two units... AHA! The guitar...
If your guitar has a battery in it, the 20 to 30 minutes fading would correspond to a battery failing and then recovering after you unplug the guitar for a while.
Posted on Apr 24, 2010
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
My pre amp is loud when it's mixted is this a tube
This unit has a lot of gain. It is probably normal. It is important to balance the inout gain and master gains of guitar amps. Not too high a setting for either.
Feb 06, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have a delux 90 fender amp solid state and it has a loud hum in it and it will not let you play a guitar or any thing else, nothing will work no sound except the hum thats all, thanks
This could be any of several problems including a failure in the power supply filtering, a tube that has shorted, or a broken ground someplace. Take unit in for repair.
Dec 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hi, I recently bought a fender hot rod deluxe which gives a very noticeable static sound. On the clean channel with the volume up to 4 it will be very audible. Is this normal or should it be brought to a...
Hello. You might have a "Tube rattle" problem. This is very common in these amps.
google "tube rattle" and you will find alot of people having the same issue.
There is some rubber tube dampers that you can buy to stop the rattling.
Hope this will help
/Daniel
Sep 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
When I turn on my fender hot rod deluxe 40W, even before plugging in my guitar, it crakles and makes noises constantly. I've had it for over 5 years and I play it maybe 1 hour a week. Is it a tubes issue?...
This is likely either a tube issue OR one with capacitors.
You need to characterize the loudness of the noises versus the settings of the controls as part of troubleshooting...
You can try tapping each tube with a pencil to see if one in failure will reveal itself.
Jun 16, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fender hot rod deluxe tube rattle.
Fender hot rod´s have an common problem on the plate resistors of the preamp and phase inverter tubes.
Check if the 100K and 82K resistors on the tube socket board are not brown. Those resistors usually need to be changed to bigger ones 1/2W.
this guy made a good document about this fix:
http://home.comcast.net/~fredholz/Justin-Holton/Fixing%20Loud%20and%20Intermittent%20Crackle%20or%20Static.pdf
Apr 01, 2010 | Fender Hot Rod Deluxe Guitar Combo...
No volume.
Are the tubes bad? Do they light up? Check the tubes and install replacements if necessary. If it's a preamp tube that went bad, just replace that one tube. If a power tube went bad then replace the set of power tubes. Be sure to get a matched set when replacing power tubes, and to bias them.
Aug 08, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Deluxe VM Tube Amplifier Logo
50 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
