Question about Conair Health & Beauty
Ww57gd scale not setting to 0.0 - Conair Health & Beauty
Set food scale to "0"
and what is it you are asking
Dec 03, 2016 | Health & Beauty
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
Why does scale print extra label?
sounds like it is setup to print a secondary label. go into supervisor mode 10 and check to make sure the secondary label setting is at 0
Aug 22, 2012 | Hobart Quantm1-1ss Quantum Self-service...
What temperature should my maytag side by side freezer be set to it has an ice maker and water dispenser thanks
Your refrigerator temperature should be between 35-40 degrees F, the freezer should be 0-8 degrees F. Both of the control settings should be in the middle, so if its on a scale of 1-9, 5 is middle, if its on a scale of A-J, E or F would be the middle, if its a temperature setting, 37 and 0 is normal setting.
Nov 09, 2010 | Maytag Refrigerators
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Reception
"Sat" stands for satellite signal. "Ter" shows the signal from a terrestrial repeater. It's not uncommon to have 0 bars on the Ter setting. Where is your antenna placed?
Jul 05, 2007 | JVC KT-PK2000 SIRIUS Radio Receiver with...
Health & Beauty Logo
77 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
