Question about Kenmore Dryers
Won't run 1. start button pushed 2.buzzes 3.won't run 4.vent to outside plugged with lint
  • 65 Answers
Sounds like motor has gotten lint into start switch and everything else. Could possibly be cleaned out but more than likely it will need a new motor.
Posted on Jan 27, 2009
My amana LE9207w2 has been taking longer and longer to dry the clothes. I clean out the vent regularly... when I use it a lot, it shuts down for hours. Now it stopped altogether with wet clothes insid
First the dryer vent should never go out of the roof thats just asking for trouble. The dryer has to work harder to get the air out. any lint that would be in the vent when the dryer shuts off just comes back down instead of being blow outside. there is probably a buildup of lint around the exit pipe on the roof. As far as your problem either you have a bad motor or there is something stuck in your blower wheel. the best way to check this is to reach inside your dryer and try to turn the drum. If your drum spins freely then hold the door switch and push the start button keep holding the door switch the dryer will be buzzing now turn the drum if it starts to go after you push the drum then you have a bad motor. If the drum does not spin freely then you probably have something stuck in your blower wheel
Aug 26, 2012 | Dryers
Tip
Taking to long to dry
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
on Jan 25, 2010 | Dryers
Have a dggx2, unit is taking 3 hours to dry clothes. we cleaned dryer vent, did not solve problem. any help thanks. ldchada@comcast.net
noavatar_s.gif seth765
Rank: Guru
Rating: 89%, 593 votes
Mar 20, 2011 | Fisher and Paykel DG08 Electric Dryer
Dryer heats and turns but doesn't completly dries clothes
Feb 13, 2011 | Kenmore 600 6965 Electric Dryer
Electric dryer runs, drum turns, gets warm, cleaned out vent, but still not getting clothes dry.
Feb 13, 2011 | Maytag Dryers
Dryer takes longer to dry, doesn't get as hot as before
Feb 10, 2011 | Dryers
Takes forever to dry, lint trap clean.
Jan 18, 2011 | Crosley CDE6000 Electric Dryer
Dryer taking too long to dry clothes
Jan 09, 2011 | Maytag MED5700TQ Electric Dryer
Dryer making a buzzing sound in the console but not running
Unplug the dryer.
Remove the rear panel.
Look on the exhaust vent for a failed fuse.
It will be narrow and about 1 and 1/2 inches long.
Remove the 2 wires and jump them together.
Plug in the dryer and start it.
If everything works OK replace the thermal fuse.
Feb 27, 2009 | Roper RES7646KQ Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryers Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
