Question about Fantech HP2190 Small Radon Mitigation Fan for 4" Duct - HP 2190
Install fantech speed control
THow do I install a speed control on a fantech hp series fan? It looks like there is a way to install into the rant control box or do I just install it on the power line (black or white) wire?
2 Suggested Answers
  • 63 Answers
SOURCE: fantech exhaust fan won't shut off.
Faulty switch (replace it) or Loose switch (wrap the body with electric tape)
Posted on Sep 12, 2009
The 15 min timer doesn`t work anymore tried getting a new switch and still nothing. Any suggestion?
Fan or electrical wiring or power source are suspect.
Fantek RTS2 is supposed to boost HRV/ERV system into high speed for 15 minutes.
http://www.iaqsource.com/category.php/fantech-ervs-and-hrvs/?category=1494
If new RTS2 is not working, then either the wire to HRV/ERV system is suspect, unit is not getting power, or the HRV/ERV system is suspect.
If you are using RTS2 for ordinary ceiling fan, then install regular on-off switch and see it that works.
Check that you are getting power to switch and to fan. Check circuit breaker.
Jun 22, 2011 | Fantech RTS2 15-minute Pushbutton Timer w/...
Thow i can install cam without cd
1) What is the 8xxxxx (or 860-xxxxxx) series number from the camera tag , or preferably...the
2) Which version of the Logitech supplied QuickCam software application/drivers is installed ?
3) What Operating System (OS) is installed?
Oct 02, 2010 | Computers & Internet
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Fantech exhaust fan won't shut off.
Sep 12, 2009 | Fantech Dryers
Need to install HP6200 deskjet
go online to compaq or hp and look up your printer , look for drivers and software download it to desktop click it and folow step by step ant it will work fine, even thow you don't have a cd rom... good luck sawdust46
Jul 25, 2009 | Office Equipment & Supplies
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Vantech bathroom fan - the damper doesn't close. How can I clean
You can use Rubbing Alcohol and a Q-Tip.
or
You can take that one out and install one of their RSK Series Backdraft Dampers.
They work very well and they are not expensive.
They can be purchased at http://www.hvacquick.com or http://www.rewci.com
Note: RSK4 is 4", RSK5 is 5" and so on.
Dec 13, 2008 | Fantech Fans Exhaust Fan In-Line
Computer fan is to loud
Do the following:
Reboot your computer.
As it reboots, press the F1 key
When it goes into your bios, look through there until you see a page that allows you to control the fan speed.
change the fan to run more slowly.
Press F10 to save and Exit.
Nov 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Fan blades or motor in Nucor over the stove hood
it is hard to get the fan off. but if you are carfull you can do it. but any large home improvment store can help with a new fan.
May 03, 2008 | Kitchen Ranges
Fantech HP2190 Small Radon Mitigation Fan for 4" Duct - HP 2190 Logo
636 people viewed this question
Top Fantech Insulation Experts
Tim Hunt
Tim Hunt
rhodesworks
Timllfixit
Are you a Fantech Insulation Expert? Answer questions, earn points and help others
