Question about IBM Ultranav Travel Keyboard 89p8500 42c0000 Sk-8840
HOW TO RELEASE NUMERIC KEY IN SK 8840
NEEDS TO UNLOCK NUMEROUS IN KEY J, K, L
My wifi password has an = and there isn't one on the keyboard
Try typing on you numeric key that you use, and then again.
Mar 29, 2016 | Tablets & eReaders
How do I factory reset u tablet?y son has forgotten the pass word. It is a IRULU 7 inch tablet. It doesn't have a reset button on it unless it is the one that says MIC
Switch off the tablet
reinsert battery
Press power + VOlume up
When start up appear release power key but keep pressing volume down key
Select Wipe data---> Yes-delete all user data
Recover Android Device in case of Forgot password pattern unlock an...
Jul 01, 2015 | Tablets & eReaders
I turned on face detectionon my tablet and no its not recognizing my face how do i unlock it?
you can reset if you do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button + volume down key simultaneously.
3. after it shows the logo then release the power button but continue pressing the volume key until the wipe or reset menu appears.
Apr 06, 2015 | Tablets & eReaders
How to unlock kindle fire
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
How do I underscore from keyboard without key
On my on-screen keyboard, it's on the numeric keypad, just to the left of the space bar.
Nov 08, 2014 | Lenovo Tablets & eReaders
Pattern unlock
If you can't remember the unlock pattern you will need to do a factory reset:
  • Power device off.
  • Press and hold down Up Volume and Power Key for 10 seconds and release after seeing the Cruz logo.
  • You will then be brought to the Recovery System screen with a Android robot and an alert triangle on the background
  • Press the Up Volume Key and the Power Key at the same time once (don't hold them down) then the recovery selections will show up.
  • With the Volume keys scroll and select Wipe data/Factory Reset and make your selection with the Power key
  • With the Volume Keys scroll and select Yes to confirm the action and make your selection with the Power Key
  • Select Reboot system now.
Oct 19, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
How do you get past a locked on a ibm thinkpad t100 computer
hold FN key (bottom left - blue) down and press F9 key...this unlocks screen
Fn-F10 will unlock the numeric pad function on the k/b.
CapsLk will unlock all caps
Jul 21, 2012 | IBM Tablets & eReaders
1) Contacts details entry - how do you enter uk postal codes which are alpha numeric, when the zip code field only permits numerics via a pop up entry number pad, other tah entering in the city field, eg...
1. In your Input method, under Settings>Locale and Text, you probably are using Samsung Keypad.
- There is a 4th column on the numeric keypad. Press the [?#+] key until it displays the alphabet characters.
2. Unfortunately, at the moment, there are only two available display options - Firstname and Lastname.
Hope this helps.
May 06, 2011 | Samsung Galaxy Tab Tablet PC
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
IBM Ultranav Travel Keyboard 89p8500 42c0000 Sk-8840 Logo
61 people viewed this question
Top IBM Tablets & eReaders Experts
Steven Wander
Steven Wander
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
