Question about Dell L375P00 (KH624) 375Watt Power Supply
L375p-00 broken how to fix - Dell L375P00 (KH624) 375Watt Power Supply
Both back doors are stuck. My window is broke it's cold in Detroit, can anyone help? The shop want $100
How to drill open a honda door that's stuck or won't open (no ...
? 0:19
www.youtube.com/watch?v=xHX6Up7HCfs
Jul 2, 2006 - Uploaded by SadieSummer How to drill open a honda door that's stuck or won't open (no real info on .... How To Install Replace Broken Rear Outside DoorHandle 1996-00 ...
How To Install Replace Fix Broken Rear Outside Door ...
? 9:52
https://www.youtube.com/watch?v=bUV6BZfVxDY
Jun 15, 2011 - Uploaded by 1A Auto Parts
How to Open a Honda Door that's STUCK! ... How To Install Replace Broken Rear Outside Door Handle 1996-00 Honda Civic - Duration: 5:47.
Honda Passport driver door lock stuck Questions & Answers ...
www.fixya.com > ... > driver door lock stuck > Cars & Trucks > Honda
Honda Passport cars & trucks driver door lock stuck questions and answers. Ask your ... 1996 honda passport defrost has stopped working ... dash vent ... Back seat doorsdo not open ... stuck. Any ideas of how to get them to open? It seems that ...
Oct 29, 2015 | 1996 Honda Passport
Tip
How To Install Repair Broken Power Front Window Regulator Buick Lesabre 00-05...
<a href="http://www.1aauto.com">How To Install Repair Replace Broken Power Front Window Regulator Buick Lesabre 00-05 1AAuto.com</a><br /><br /><utube src="zbQDMaZ2Cm0"><br />
on Jun 16, 2011 | Buick LeSabre Cars & Trucks
Apparently, the spring under the timer dial on my 4001 timer has been broken and the timer will no longer trip the trippers. Can this be fixed? It is a nearly-new unit and I like it.
Open following link for Paragon resources:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Individual parts are not sold except for X2772 tripper.
Move the manual override lever back and forth and see if load turns on-off.
Watch if on-and-off trippers are moving override lever back and forth, to see if problem is a worn tripper instead of broken spring.
Replacement 4001-00 timers are sold, even though Paragon is no longer making timers except defrost timers.
http://www.mdappliance.com/RBS-4001-00.html?mv_pc=00015
Replacement timer is Intermatic T101
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jun 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Hi my name is Zeldah.i am a south African,working in Saudi Arabia,my LG50L LCD screen is broken.where can i fix it in south africa.thanking you in advance.
You could contact LG at :-
Phone Customer Service : 0800 54 54 54 (Monday to Sunday from 08:00 to 17:00)
Reception : 011 323 8000
Fax : 011 323 8510
For list of repair centers, kindly check the below link :-
http://www.lg.com/za/support/index.jsp
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 27, 2011 | Televison & Video
My dell xps 400 was shutting off and all i was getting was a solid amber light in front. I was able to hold it in for a bit and then press it and turn it back on for about 2 weeks now. It finally shut off...
You more likely had a temperature issue with the CPU.
Had the CPU fan started to sound like an airplane warming up?
If so, you may have finally burned out the CPU.
Yes it's possible that it was reporting a problem with the power supply, but the only way to know for sure is to replace it.
In the meantime, eliminate everything else.
Disconnect power from EVERYTHING except the motherboard.
If it powers up, then it's possible that either your motherboard is failing (and now works under the decreased load), or one of the things you unplugged has failed.
If the unit springs to life, turn it off, and start reconnecting things.
If it fails constantly whenever 1 specific thing is plugged in, that thing or the motherboard chip that controls it is the problem.
Mar 12, 2011 | Dell XPS 400 PC Desktop
I cut the cord in order to make the length shorter. i twisted them together and used electrical tape to insulate the attach point. i tried this several times, and im not even getting a broken signal.
No amount of comforting words is going to help you fix what you broke.
You might have some luck calling Sony to see if you could order a new cord.
https://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Shop By Phone: Priority Service: 1-239-768-7691 Toll Free Service: 1-800-488-SONY (7669) Phone Hours:
Monday to Friday - 8:00 am to 12 am (Midnight) ET
Saturday and Sunday - 9:00 am to 8:00 pm ET
Jan 12, 2011 | Sony MDR-V500 Professional Headphones
Hardware problem occurred
Check to see if the cover arm broke off or has missed the lever that makes it operate when you drop the cover down if this does not do it Let me know I will see if I can find anything else but that's all I can think of at the moment, get back to me if that does not fix it and I will see what I can find for you, do the simple first. Thanks for using fix-ya
Jan 19, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Cybershot DSC-P200 broken battery/memory stick cover
I suggest that you contact Sony PAS to get the new Battery cover at 1-800-488-SONY (7669)
Phone Hours:
Then, contact the nearest dealer to get the Battery door fixed instead of sending for service.
All you have to do is, press the pin on both the sides of the Battery door and insert in the hole available for battery door on camera.
Sep 26, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Feb 16, 2008 | Office Equipment & Supplies
Dell L375P00 (KH624) 375Watt Power Supply Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
