Question about Dryers
1.push start button 2.buzzing noise 3.won't run
  • chfoss Jan 27, 2009
    how do I access the motor ?
  • Dryers Master
  • 8,220 Answers
Reach inside and turn the drum by hand. If it is hard to turn then find out what is wrong. oil the wheels replace the slides. If the motor is locking up drill some holes and oil the bearings. Work the motor loose and retry.
Posted on Jan 27, 2009
  • Dan Webster
    Dan Webster Jan 27, 2009
    Depending on the type of door the dryer has, is how you approach the
    access of these dryers. Mostly though you yank out the filter
    first.Remove the 2 screws in the filter housing on top.Then use a putty
    knife to pop the top. Remove the screws holding the front panel on.
    VERY IMPORTANT! Raise the front up an inch before pulling forward or
    the panel clips will break! Some models have a panel on bottom. If they
    do then this panel must come off first. Then you remove the door
    springs and back off the screws holding down the bottom of the door
    panel. Then pop the top and remove the screws on top to get the panel
    out of your way. All you gotta do is lift out the drum then all that is left is the motor.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Have ptdn600emwt dryer when pressing start button makes noise but does not run
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Feb 27, 2015 | GE PTDN600EMWT Dryer
After doing a few cycles the dryer would not turn on. Pressed the start button and it made a buzzing noise 2-3 times then no noise at all. After letting it cool, took the dryer apart, cleaned it out and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Dryers
When I push the "Start" button there is a buzzing
heatman101
Jun 15, 2011 | Fisher and Paykel DE06 Electric Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer will not start
If the buzzing noise is from the vicinity of the switch, then suspect the push button contacts, if from within the bowels of the machine, then something is probably preventing the motor from running up to speed, it is stalled - (there are buzzes, and buzzes).This could be many things, from something mechanically jamming the drum, to worn bearings or a faulty motor/start circuit.
As I am not aware of your skills, I am not asking you to take the back off and have a look.
Jan 15, 2008 | Dryers
Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Jan 05, 2008 | Dryers
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Dryers Logo
102 people viewed this question
Top Dryers Experts
