Question about Xerox Phaser 3100MFP/S Laser Printer
FUSER DERECE HATASI - Xerox Phaser 3100MFP/S Laser Printer
Eror e10 epson sx218
http://www.bitmeyenkartus.com.tr/EPSON-PED-HATASI-RESET-PROGRAMLARI,LA_327-2.html#labels=327-2
Feb 19, 2014 | Epson Stylus Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
User error
FUSER ERROR:
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Error code J00
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
Jan 07, 2009 | Kyocera KM-1510 Copier
Installing lexmark 5150 to my home computer
go to driverguide.com take a small survey (dont buy anything) and register its free
Jul 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Xerox Phaser 3100MFP/S Laser Printer Logo
416 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
