Question about Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon
Amtrol st-12 where do i find a pilot light - Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon
Amtrol wh7p
https://youtu.be/pUOBR1k3KvM- try seeing if this video answers anything. If not, there are a bunch of others about water heaters; just look around until you find one that looks similar to the one you have and watch. Sometimes, you get lucky lol
Jun 14, 2017 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Amtrol Boiler Mate WH-7P (oil). We had a power failure, and when the power came back on the water heater did not. We've checked fuses, etc., but there doesn't seem to be power to the water heater. We can't...
If you check for power at the tank, (the black and white wires) you should read voltage, either 24 vac, or 120 vac, depending on how it is wired. If there is no power there, then you will have to chase power back to where you do have it. There is no fuse or reset button on this model.
Jan 19, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Short buzzing noise every few seconds from hotwater tank
it maybe that there is a small leak at the connection.try to remove the tank and put teflon tape on the connection.this may fix the problem.if this does not fix the problem,it may be possable that the amtrol has a pin hole in it.this may hve to be replaced.good luck with your project
Sep 29, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Therm-x-trol st-12 leaking
Never seen one leak other from the seam or the top or bottom.
Mar 14, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Air in hot water lines only after installing thermal expansion tank. tank is mounted below water line .
Does you system have an auto air vent - has a cap like tire valve. cap should be left loose.
Mar 05, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
How do I change a amtrol thermal expansion take, Is it as easy to unscrew and put the new one after shutting of the water supply
Yes. After attaching the new one,check air preasure with a tire gage to match the recomandation that come with the tank.
Feb 23, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon  Logo
Top Amtrol Water Heaters Experts
Andrew Bugbee
Gil Shultz
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
