Onkyo SKW-780 No sound
I have an Onkyo SKW-780 powered subwoofer. When it is pulled in, the blue led turns on saying the sub is in standby/ready to play. BUT, when the input cable is slightly inserted and removed, the normal ruffling sound from speakers is NON-extant. I have checked for a blown resister, but I cannot find one. I have tested the receiver with a secondary sub; Full audio. Anyone have any thoughts?
4 Suggested Answers
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
Grubhead
  • 5259 Answers
SOURCE: No sound coming out of my Onkyo SKW-200 subwoofer
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Posted on Feb 02, 2010
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
Sub woofer not receiving signal from onkyo HTR520 , bought it in 2007, it works when hooked up to another source. can it be hooked up without using the sub woofer out put on the onkyo
The best thing to try is a factory reset of the Onkyo. The subwoofer out may be stuck off, even if the settings say its on.
hold down the Video 1 and Power on/ Standby buttons. The display should say Clear, then enter standby
turn it on and try the sub again.
since its a powered sub, you're not going to have much of a choice in other outputs without extreme distortion.
also, if that model has two zones, make sure zone 2 is off.
May 05, 2017 | Onkyo Audio Players & Recorders
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
Feb 02, 2010 | Onkyo SKW-200 Subwoofer
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
217 people viewed this question
 Grubhead
Grubhead
