Question about Kensington 64376 Keyboard
Can't access Euro currency symbol on the keyboard
My Kensington 'Comfort Type Multimedia Keyboard' has the Euro symbol on the 5-% pad, to the right of the number 5. I have tried pressing & holding down 'Ctrl' and 'Alt' both together & separately as I have on other keyboards but to no avail. I have gone into Control Panel - Regional & Language - keyboard symbols which gives the Euro sign as a demonstration of currency but can't see a way further . My operating system is Vista Business.
  • Anonymous Feb 11, 2009
    me also facing same problem
2 Suggested Answers
  • 34 Answers
SOURCE: Can't change the decimal symbol on my Kensington 33006PocketKeyPa
You can customize this setting in the Regional and Language Options in the Control Panel for Windows,
Posted on Dec 27, 2008
yooperbud
  • 8637 Answers
SOURCE: Mouse not responding
Are the batteries good?
Try
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 20, 2009
How to use the rupees symbol in logitech k200 keyboard
you may download Rupee.rtf file from internet..Place it in Start> Control Panel > Fonts....When u open an editor like MS Word...for rupee symbol select "Rupee" from font drop-down and for typing it use the key just above the tab key on ur keyboard. You are done.
Nov 16, 2011 | Logitech 967437-0403 Keyboard
I have just bought a MX5500 keyboard and mouse. As a UK citizen I need to be able to type a pound sign and a euro sign but this is a US keyboard. Can you help
Unfortunately, a US keyboard is set up to send out keycodes for the US symbols. If you're using Windows 7, this information from Microsoft may be helpful.For XP, you can try changing your regional settings in the Control Panel (Start > Control Panel > Regional and Language Options). You can try changing the keyboard layout and see what happens.
One sure way to get the symbols from any keyboard is by using alt codes. Hold down the ALT key and (on the numeric pad) press 0128 for the Euro symbol (€). ALT-0163 gives you the Pound Sterling symbol (£).
Jul 06, 2011 | Logitech MX5500 Keyboard/Mouse
+keyboard with Acer AspireE500-A970. How do I access the Euro symbol (lower case with Number 4) on the keyboard? Arthur
To type the Euro sign in Windows, you press the alt key+0128. As for the Sterling pound symbol, you can type it by pressing the alt key+0163. You can have a look at this site where it lists ways to type different currency symbols:
http://www.fonts.com/fontent/fontent_home.asp?nCo=AFMT&con=fyti_currency
Please note that you have to type the 4-digit code on the numeric keypad (do not use the normal number keys) while holding down the Alt key.
Hope this helps.
Jul 05, 2011 | Acer NSK8458AN Keyboard
In HP keyboard for typing percentage we use to typy % for typing five we use 5 , my question is to type euro in 5 how to use . please reply me , thank you.
There were also past discussion in the forums, such as:
http://www.proz.com/post/41613
€ = right ALT + "E" (or, left CTRL + ALT + "E")
£ = right ALT + "L" (or, left CTRL + ALT + "L")
Hope this helps.
Jan 15, 2011 | Keyboards & Mice
How do I access the Euro Currency symbol which is on the same key as % and the number 5?
hi sir, to access the Euro Currency symbol which is on the same key as % and the number 5 please press the "AltGr key and 5 together". If your keyboard doesn't have AltGr key you can press "ALT key and 5". kindly rate me.. thanks for using fixya..
Feb 12, 2010 | Keyboards & Mice
How I connect my KeyBoard with PC kensington Model:64355 FCC id:H8grfkb21 M Amjad KhanPur Pakistan
Go to this site:
http://us.kensington.com/html/3846.html
Almost at the bottom of the site you will find your keayboard,"Kensington Comfort Type Wireless Desktop Software", and you will find drivers for it, and you will find instructions how to install it
Good luck
Dec 10, 2008 | Kensington Comfort Type Wireless Optical...
Apple key no longer working
The Kensington keyboard is being recognised as a PC-style keyboard, and the software has swapped the action of Apple (Command) and Alt (Option). Go to System Preferences > Keyboard and Mouse, and set the Modifier keys correctly in the Keyboard panel.
macs2u
Jun 16, 2008 | Kensington Comfort Type Wireless Optical...
Try
May 24, 2008 | Kensington Comfort Type Wireless Optical...
Kensington 64376 Keyboard Logo
545 people viewed this question
Top Kensington Keyboards & Mice Experts
Brian Sullivan
Brian Sullivan
Laxman Bisht
Laxman Bisht
Are you a Kensington Keyboard and Mice Expert? Answer questions, earn points and help others
