Question about Fujitsu 24R1 Air Conditioner
Fujitsu air conditioner AST24RSG-W
I have a fujitsu a/c model number AST24RSG-W
it stop working 2 days ago`
fuse is ok, power suplly to the mother board is ok
reset SW3 switch in mother board
no dispay on the unit
can somebody help me please
do I need to replace the mother board?
  • Fujitsu Master
  • 8,220 Answers
Might be the capacitor. If it swollen or leaky it bad Kimosabe
Posted on Jan 27, 2009
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
How to turn the Timer off on Fujitsu AC Model AR-RAC3E? I have tried several times but failed. The Timer light flashes three times every several minutes. The AC does not work at all. The Operation
remove front cover-pull from bottom and lift up at top reset button is above lights try that first , other checks remote battery, control wires 1-2-3 from condenser to evaporator board.
Jan 20, 2015 | Fujitsu Heating & Cooling
Why did my 5,000 btu artic king air conditioner stop working after having it less than one day?
Can't answer why as no details as to how it's failed, but if you've only had it a day return it to the vendor.
you have installed it as per instructions? Is it draining ok? No error codes? Checked the power outlet? Fuses or breakers?
Jun 17, 2014 | Arctic King MWK-05CMN1-BI7 5,000 BTU...
My fujitsu heat pump died three days ago, purchased 6 years ago so warranty now expired. Service agent who sold me the unit suggested this model has caused many problems ''horror stories he said'' for his...
Yes you can check these out at Consumer Report.com. You can also order you a new unit for about 1/2 price on line. Just type in Air Conditioning mini splits Google this. I bought 2 ton heat pump on line from Amcore for 1100 includes pipe and all the wire you need. Russ Included shipping.
Jul 22, 2009 | Heating & Cooling
Fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
It sound like you have a direct short in the compressor ,Usually it means you have a bad compressor,but sometimes it could be a loose wire or bad outdoor motor. Ive installed about 10 of these units and still have yet to have a bad compressor.It could also be a bad circuit board in the outdoor unit.I wish I could narrow it down better but thats my best guess!Thanks ---Nate
Jul 14, 2009 | Fujitsu 24R1 Air Conditioner
I have a ast24rsg-w after 3 minutes the circut breaker blows
this sounds like the compressor has shorted to ground, must be verified by ohm check
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Fujitsu 24R1 Air Conditioner Logo
317 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
