Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Motor running a lot
It seems like the motor is running often and it is louder than usual. i've cleaned the coils under the refrigerator. are there others i should clean?
  • 31 Answers
9360gabbs,  The significant thing that you list is... it is louder than usual.  You indicate that you have cleaned the coils under refrigerator.  Try and roll the refrigerator out from its normal location so you can get behind it.  Remove the cardboard or metal cover across the bottom area of the refrigerator.  Check and see that the fan next to the compressor is running and that the blades are clean from dust, etc. Sometimes the condenser fan dies and must be replaced sometimes the blades are covered in dust, etc and causes a decreased volume of air to be moved by the fan.  Make sure the entire area is clean from dust, etc.  Be sure to replace the rear cover that was removed.  Very important!  Hopes this helps you! HandyHenry
Posted on Feb 07, 2009
I bought an ER2MHKXPB two door with a top freeze, no ice maker 3 years ago. All of a suddent it runs almost continuously and the motor/compressor noise is considerably louder. It's still cooling and...
Check to make sure the coils behind the front kick panel are clean, If not buy a coil brush and clean them. If they are clean you may have check the thermostat.
May 13, 2011 | Whirlpool Refrigerators
The motor is running alot and with a louder running noise than usual, the refrigerator is working fine
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | LG LRFD25850 French Door Refrigerator
Hi woke up this morning and the divider between the freezer and refridge compartments was very hot. Kitchenaid model ksbp25fkss. opened back panel, and compressor was also very hot. also seemed to be...
if it is making a lot of noise then your compressor is going out, if it is full of dirt dust or debree vacume it, or if you have a air compressor, then blow it out, but unplug your fridge to let the compressor cool down, if it is cold outside and you can wheel it there with no problem then you can clean it . you might have a freon leak or a stuck valve let it get cooled off and try again
Dec 12, 2010 | KitchenAid KSBP25FKSS Side by Side...
MY frig is only 1 month old. Model# GTH18DBXCRWW. It has started running louder than usual and seems to run longer. I misplaced the manual and need to know what the problem could be.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 25, 2010 | GE Refrigerators
Motor is running continuously and is loud
The coil ubder the frig could be filled with dust/dirt and no air is flowing over it to remove the heat. This will causecontinuous running and force the compressor to work harder and louder. A loss of some refrigerant (freon)will cause continuous running but not likely to cause louder running. The fan motor in rear of frig at the compressor could be worn out and running slow or stopped and without this air flow the compressor never stops and runs loud. Also, the door gaskets (especially the bottom part could be torn and bot sealing well; this will cause continuous running but not likely loud running. Goodluck, Macgivor
Oct 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Oct 14, 2009 | Avanti WC681BG Wine Cooler
Whirlpool upright freezer- model EEV151N is running but not keeping things frozen. Making a whirring noise louder than usual. At least 24 years old.
Possibly has a restricted capillary tube. Possibly has a extremely dirty condenser coil. Possibly has a bad compressor which will run but has bad valves so it doesnt actually pump the refrigerant. If the condenser coil has a fan (unlikely) it may be dead and causing the unit to run much higher pressures than normal which could cause this. Only thing you really could do would be clean the condenser coil. Anything else would need to be repaired by an Refrigeration Mechanic.
Oct 10, 2009 | Whirlpool Upright Freezer EV161NZRQ
Whirpool refrigerator runs too long
First thing is to check the condenser coil( outside coil) and see if dirt has accumulated on it. if so clean it off. The condenser coil should be located under the fridge, or behind the fridge.If you do clean it, and its still running a lot, then its possible that the unit is low on refrigerant. If that's the case you will have to call a service tech to look at it
Jan 28, 2008 | Refrigerators
Noisy [like loud motor running] almost all the time--for about a week
when you state "it's the compressor running all the time", does this mean it hardly shuts off? if so need more freon
May 27, 2007 | KitchenAid KTRS22EM Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
