Problem with electronic unbalance detection device
Drum starts to spin then stops
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: wont spin renewed carbon bushes and new motor ,belt okay.can you advise where the electronic detection device is on the machine,how can it be repaired
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
Posted on May 22, 2009
  • 69 Answers
SOURCE: drum hitting sides of machine in spinning cycle
It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
Posted on Dec 27, 2010
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
My indesit washer dryer makes a hell of a racket on the final spin. Tje bearings are fine but it looks like the shocks dont do anything. I can move the whole drum forwards and backwards about 2...
yes
it is called an air dampener and controls the drum movement to stop unbalance when starting
they come in a pack of 4 and average price is around $90.00aud
Dec 14, 2017 | Washing Machines
The machine begins just fine half way through a cycle it stops. Sometimes it runs with no problem. One time we got a code of (UE) I think not sure.
UE = Unbalance Error. For bulky loads, use a lower spin speed. For regular cycles, use a larger amount of clothing per load, and / or a lower spin speed. You can load the drum with dry clothing up to the point where you are just able to reach your arm in to touch the back of the drum. Very small loads can cause more frequent off balance situations.
Mar 15, 2011 | LG WM-2277HW Front Load Washer
Drum hitting sides of machine in spinning cycle (unbalance)
Dec 27, 2010 | Hoover Washing Machines
I have a KENMORE WASHER MODEL 11020894990.The slow spin comes on and works fine but when it stops to begin the faster spin it makes a klunk klunk noise and will not spin.
Well the klunk-klunk is the Break grabbing, to stop it, as it is detecting, what it thinks, is some sort of Unbalance or Overload, or detecting a motor fault, etc, real or not, and is shutting itself down because of this.
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer sounds like an airplane taking off when in spin cycle. It is really loud.
its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
Jan 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Zanussi 1600 aquajet not spinning
It could be the unbalance control that feels that the clothes has too much unbalance, or the brushes in the motor is worn, and need to be replaced.
Nov 19, 2007 | Zanussi FJD1666W Front Load Washer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
