Question about Spidem Trevi Digital Coffee Maker, Espresso Machine
Spidem trevi digital plus coffee machine not working as it should
Machine is supposed to grind beans as it dispenses the water, it is grinding at the end of the water dispensing cycle.
It sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Posted on Nov 20, 2009
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
Coffee come out fast and is weak ...
Hi
2 things can cause this.
1. the grind is too coarse. That would be the big knob in the bean hopper. Turn it down when its grinding only. From the factory it is set on 8.
2. The grinder has seperated internaly. That is a tough one to fix, as the grinder should be taken apart and cleaned, then reassembled.
Oct 02, 2010 | Spidem Trevi Digital Plus Coffee Maker
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Spidem Trevi Automatic Coffee Machine
Try to adjust the grinding little finer, when you have adjust this you have to make 3-4 cup of coffee to get the final result.
Jul 03, 2008 | Spidem Trevi Automatic Espresso Machine
Grinding mechanism
It might be jammed, you could try to unjamm it. but make sure its unplugged..
Feb 11, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi Digital Coffee Maker, Espresso Machine Logo
192 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
