Question about Refrigerators
My powerpoint trf285 intergrated fridge rear wall freezing up
Tempeture control not working
5 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Posted on Jan 06, 2007
huuum
  • 750 Answers
SOURCE: Whirpool Fridge
Hello Maxleilao,
Welcome,
You said, Both Freezer and Fridge compartments stopped keeping optimum temperature. Freezer compartment is working as a fridge, and fridge also not keeping the temperature as it should. Both temperature controls are on maximum (I actually tried many different combination's with no luck).
What is the model #.
How old is it?
If the fridge is only a couple of years old , try turning it off and then! unpluging it for 5 minute and then
restarting it.
What happened?
if nothing good then most likely it is this next task!
It should be on a sticker inside the door jam or close to it on the inside wall of the fridge.
If it is real small like a counter high fridge, the number may be on the rear.
If the fridge is full size fridge check in the rear to locate where the condenser is. (lt looks like a thin row of black tubes that the freon travels through).
If not and they are under the fridge behind a removable plastic grille in the front of the fridge.
If this is the case then remove the plastic grille to see if the rows of thin (black tubes) called a condenser is covered with one to two inches of dust and not visable yet due to the blanket of dust!
This makes the condenser (black tubes) hot and unable to cool.
Air is sucked in from the front and passes over these tubes and cools the freon.
That is making it hot and the fridge and freezer warm.
You will need a flash light,
The plastic grille comes off when you press down on the top and up on the bottom together. Like squeezing the grille with your fingers until it comes off in your hands.
Get a flashlight, and get down on the floor and look under the fridge at the condenser. If all you see is an inch or two deep of lint and dust, then you need to buy a refrigerator brush at the hardware store and clean the thick coating of dust off.The brush is one inch wide and round with a very long handle 36 inches. Do this very slowly and gently. Remember the freon is in these tubes so you don't want to bend them and get a leak.
I know this was a long explanation but if this is the case I just saved you a service call.
It will take some hours to get cool again if this did not cause any damage to the compressor!
Some times all night till it reaches the max. temperature.
If there is no condenser below, or this does not do the trick, you may need to replace the thermostat!
or have a low freon level.
Waiting for your response
Let me know!
Huuum
Please remember to leave a rating at the end!
Posted on Oct 22, 2008
  • 396 Answers
SOURCE: water freezes in refrigerator, what is problem?
Refrigerator temperature setting too low?
Posted on Oct 10, 2009
heatman101
  • 43501 Answers
SOURCE: my powerpoint fridge freezer model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 21, 2011
Why hoover fridge not cooling or freezing?
is it warm or hot to touch? no sticking defrost timer? if not then check the cold control tempeture thermostat, the thermistors, and the door seals, lastly may have a coolant problem, do any of the back copper tubes to the compressor feel cold to the touch
Feb 20, 2015 | Hoover Refrigerators
I have a BJ505T-L the fridge and crisper are freezing up, is that a thermostat issue
would check the thermistors and the tempeture control thermostat
Feb 19, 2015 | Refrigerators
My PowerPoint f/f mrf222ff keeps icing up in fridge compartment
check the defrost timer, defrost terminator, thermistors and the tempeture control thermostas also check the vent damper? open or close to much
Feb 16, 2015 | Refrigerators
Rangemaster fridge freezer not freezing temp 0.2 what should it be
could be condensation from a bad door seal? might also check the tempeture control thermostat
Feb 14, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Jan 21, 2013 | Haier Refrigerators
Everything is freezing in our refrigerator even
Your thermostat has failed and requires replacement. If the fridge is very old you could use a mains interupter device that has a temperature sensor that is placed in the fridge. There are several hobby kits for such devices usually used for converting old fridges for wine storage.
Sep 29, 2009 | Frigidaire Refrigerators
Freezing at any tempeture
I ordered a new thermostat (about $40 with shipping) & installed it. It's pretty easy to replace. The fridge has been working fine since.
Jan 14, 2009 | Sanyo SR-4910M Compact Refrigerator
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Touch Temp Controls
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
Digital Tempeture numbers off
Those control boards are sort of flakey and any kind of power surge, etc. can really goof them up. If you check under the very bottom of the fridge there should be a technical sheet taped up to the underside in a plastic bag. Take that out and read it to see if there is a test reset you can do before replacing the board.
Jan 03, 2007 | LG LRBN22514 Bottom Freezer Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
