Question about Sherwood RVD-6095R Receiver
Harman kardon 3270 rds looses presets - Sherwood RVD-6095R Receiver
How do I preset the FM stations and save them?
You may be using the wrong procedure. Some receivers require you to manually tune to the desired station, then press memory.
Dec 09, 2015 | Harman Kardon HK 3270
I have the HK AVR 65 Amp. After power failure I loose all my preset settings.
Hi, there is a super capacitor on the front panel PCB (C 906), value:
0.1F 5.5 V.
Just replace it, and hope it will resolve the problem.
Oct 13, 2012 | Harman Kardon AVR 65 Receiver
Will not retain presets
Many times a capacitor is used in place of an actual battery. On Harman Kardon receivers this component is on the front side circuit board behind the receivers external display. Harman Kardons website provides the actual location and part number if you dig around for the service manual PDF.
Jan 12, 2012 | Harman Kardon AVR 320 Receiver
I'm unable to turn ON my Harman Kardon AVR 300 rds power lisht is in red colour
Hi, Check the speaker wires that they are not shorting. Check the fuses on the back and then unplug it for 10 minutes. Good luck.
Sep 10, 2011 | Harman Kardon AVR 300 Receiver
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
How to erase preset fm stations and then set my favorite stations in the preset fm stations again
You may have to 'overwrite' the existing stations.
http://www.retrevo.com/support/Harman-Kardon-AVR-210-Receivers-manual/id/386bh148/t/2/
Feb 06, 2011 | Harman Kardon AVR 210 Receiver
One speaker output does not seen to work. All wires are tight.
Check for a cold or broken solder connection inside the unit. The left and the right channels are almost identical circuitry. Compare the good channel to the bad one.
Nov 23, 2010 | Harman Kardon HK 3270
Harman Kardon HK 3270. The receiver looses the presets at power off.Is there a battery to be replaced for storage of the presets?
I believe it is actually a memory capacitor that has to be replaced. It is soldered directly into the board and requires quite a bit of know-how to replace.
Hope this helps,
Thanks,
Jan 09, 2010 | Harman Kardon HK 3270
Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Oct 25, 2008 | Harman Kardon AVR 7000
Sherwood RVD-6095R Receiver Logo
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
