Question about MSI G31M3-L V2 Motherboard
MSI G31M3-LV2, Bios XD settings
Can NXorXD be enabled in this motherbaord bios, to instal Windows 8?
  • MSI Master
  • 3,606 Answers
Hello the homepage is here:
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html#/?div=Driver&os=Win7%2064
Here is no support for windows 8, and the cpu must support the 64bit
architecture, in order to install the windows operating system.
You must also have, at least 2 gb of ram.
Download the upgrade assistant here:
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8
To find out.
Good luck
Posted on Jan 22, 2013
  • 86 Answers
SOURCE: cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Posted on Jan 20, 2008
blubaustin
  • 242 Answers
SOURCE: ms-6714 msi main borad bios
http://global.msi.com.tw/index.php?func=downloadfile&dno=1287&type=bios
Posted on Jan 22, 2009
  • 254 Answers
SOURCE: Problem installing Windows 7 on MSI KM4M-V
Id say with those specs Id be sticking to XP mate , win 7 like vista munches resources and without them it can be a pain
it maybe time to shout your self an upgrade , plenty of bargains at the moment.
hope this helped
Posted on Feb 04, 2009
SOURCE: Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Posted on Feb 10, 2009
proton77
  • 1183 Answers
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Posted on Aug 15, 2009
How can i install my 500 gb sata hard disk, in bios i din't found any sata settings...plz help
There are no SATA settings in BIOS for most systems. As long as your motherboard has SATA connectors, the BIOS should recognize that the drive is installed and then you use Windows to format it for use.
You should see the drive listed in the drive section of the BIOS after you have connected both cables for it (power and motherboard).
Dec 09, 2014 | VIA Msi Ms-7071 Ver:1 Pm8m2-v Socket 775...
Error code 0x0000005d
Sign in to vote
Error Code: 0x0000005D: Your CPU is not compatible.
To install Windows 8 Release Preview on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system.
To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled") feature, within the BIOS security settings.
If the BIOS setting for the NX support option is not available on your system, you may need to contact the manufacturer for updating the BIOS. Note that some older processors may not contain these features and will be incompatible with Windows 8 Release Preview
Mar 05, 2014 | HP Cobra Motherboard Asus P4sd-la Pentium...
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
I just finished installing Win 8 on a Compaq evo ultra slim after restarting I get error code 0x0000005d what can I do , is my motherboard not compatible its a pentium 4
Go to BIOS, find option 'Data Execution Prevention', and enable it. Moreover, enable option called 'Virtualization Technology (VT)' feature, in a case; you are trying to install Windows 8 from virtualization software like oracle or VMWare.
How to enable above option
To enter in BIOS, restart computer and on very first screen find a message like this:
'DEL to enter setup'
'Press Esc to Enter Setup'
'BIOS Configuration: F2'
'F10 to Enter Setup'
Carefully find any message on your screen and press respective key to enter in BIOS.
Once you enter in BIOS setting, go to Advanced Options and select Processor then No Execute Memory Protection, if not, then Security > Options and Select Execute Disable. Change this to 'Enable' or 'On'.
Save changes and Exit Bios Setting if you perform Windows 8 installation in a new PC, otherwise move on to next step
Enable Virtualization Technology (VT) feature
Go to BIOS setting by following above-mentioned steps. Go to Performance options. Change the Virtualization feature to 'Enable' or 'On'. Save changes and Exit BIOS setup. Proceed to next step if your system supports the security feature. This is how you can solve the issue.
Nov 01, 2012 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
I installed a new G31M3 v2 mobo...
The first thing to ask yourself, is if the motherboard supports the CPU you installed. Also, check the BIOS settings to see if there were any settings that were not default.
Without checking the motherboard specs, I hope you matched the bus speed of the CPU, motherboard, and memory.
Nov 23, 2011 | MSI G31M3-L V2 Motherboard
The board starts up but with no display
Try to remove RAM from modules then plug it again, also you can reset Bios settings to its default setting..If still happens then your need to try to upgrading your Bios...
Another possibility is usually caused by memory, and you can try with different Memory.
Aug 06, 2011 | MSI G31M3-L V2 Desktop Board - Intel G31 -...
I have using msi k8mm-v ms-7142 ver:1 motherboard with amd sampron 2500+processor its audio driver is not working i download and install ac97 audio from msi site but it is asking to enable bios audio...
You have to double check the cmos or bios settings which the audio are enabled mostly on integrated peripherals inside of you bios! Tap DEL key to enter bios setup.If the audio settings are enabled other solution is to upgrade your bios firmware. You can actually download the update from MSI official website. But be careful while updating your bios firmware, be sure to download the exact model of the motherboard and you must have back up battery or UPS while performing flashing your cmos because if interrupted while flashing causes of fluctuation your motherboard will be dead set.Always remember to back up your cmos before flashing it. After flashing your cmos, install again you downloaded audio driver. The audio driver must be compatible with your operating system in order to install the driver. Hope this works for you!
Dec 29, 2010 | MSI K8MM-V Motherboard
Brand new G31M3 V2 MSI motherboad, fresh out the box. I hooked up all the wires correctly (i triple checked them) and installed the new graphics card, wireless internet card, and tv tuner card, and...
Remove everything except CPU and 1 stick of RAM. Attach monitor to onboard graphics and under Integrated Peripherals in BIOS there SHOULD be option for display, it needs to be set to PEG so it looks for a PCIe graphics card first. If you still get no picture, DOA motherboard.
Aug 28, 2009 | MSI G31M3-L V2 Motherboard
MSI G31M3-L V2 Motherboard Logo
206 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
