Question about Mitsubishi Heating & Cooling
Mitsubishi fdkn 204 hen not blowing hot air - Mitsubishi Heating & Cooling
3 Suggested Answers
  • 1214 Answers
SOURCE: Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Posted on Jan 22, 2009
  • 400 Answers
SOURCE: mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Posted on Mar 09, 2009
Heater stopped blowing hot air. engine won't idle hen hot
check oil level add if low.. check antifreeze level add if low..retest
Dec 08, 2013 | 2002 Ford Mustang
2009 galant, added coolant.. still blowing hot air
Hi, there are several reasons your vehicle may be blowing hot air through the vents, such as a need to recharge refrigerant. There could also be a problem with the air conditioner's compressor. Vents will blow hot air if the compressor does not activate when the A/C is turned on. There may be an obstruction in the system, or the blend air door inside the HVAC unit may be stuck in the HEAT position so no air goes through the A/C evaporator.
May 25, 2011 | 2009 Mitsubishi Galant
Our mitsubishi FDKN204 HEN A/C unit gives us error U00E33. What does this mean?
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Feb 03, 2011 | Mitsubishi Heating & Cooling
Air conditioner blows hot air . gauge shows full .
It needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jul 26, 2009 | 1994 Mitsubishi Diamante
Problem with air conditioning on 2001 mitsubishi mirage. "Sometimes" will not blow cold, just hot. Coolant level ok. Usually will will start blowing hot after runnning air while car is stopped at idle....
the air conditioning system has most likely drawn moisture this is not good take it to have the system recovered and a new restrictor valve put in. leak checked and recharged
Jun 22, 2009 | 2001 Mitsubishi Mirage
Heater wont blow hot air in van. How do i fix it?
add coolant to the radiator and it should help circulate it and warm the air up
May 07, 2009 | Mitsubishi Minivan Cars & Trucks
Jan 22, 2009 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
