Question about Cell Phones
I want the ics AT8PS56P,GLBOGS 649,LM 324,CS16210Gp
My tanashi home theater gets dead so i want the processor ics place in display listed above
Benimur
  • 6966 Answers
SOURCE: NEED EXTENSON CABLES FOR 2 SPEAKERS
Normally, speaker wires of any length are available from most electronic stores and/or audio/video stores. Even those shops that do car audio installations would have them in their inventory. The only requirement/specification you would need is the power output of your home theater and the required length. The longer the distance, the better the bigger the wires. Speaker wires always come in pairs and have color coding to designate +/-.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
dunnbiker
  • 8546 Answers
SOURCE: monitor problem
I don't see any OSD in the RX-V490 owner's manual. This unit only passes video through from a video source, like a VCR.
Posted on May 16, 2009
  • 336 Answers
SOURCE: ic for home theater
Check the part number again my bet is it starts with tda not tba and I could not find a tda2769. mcmelectronics.com has a tda7269 output IC
Hope this helps
Posted on Nov 09, 2009
  • 4917 Answers
SOURCE: need unlock code for Blaupunkt car 2003 (f) radio
Try
www.ukbookshelf.co.uk
Posted on Jun 05, 2010
caroldon
  • 17130 Answers
SOURCE: Home Theater DVD No. MCD139B Amplifier surface
Please try to check up at the shops in Lamington Road.many of them specialise in SMD. if not you can order with an advance payment. Replacement of the IC must be done with the proper tool after spending so much. hence please ttry with the Maker 's service centre from the site and get a quote. Proceed if the cost is suitable or else try to get a salvage board from another damaged ( other section) model. Check this out.
Posted on Jul 14, 2010
Mms 5650 small amplifier ic number required please.......
Would you please give me more information, as the number of pins of the ic,? does it has just one screw above in the metal flange?
TDA7293 comes to my mind...let me know to help further..
Oct 05, 2013 | Dell Mms 5650 5.1 Surround Sound Home...
My sony dav-dz260 will not power on looks dead
Possible that the main processor section is faulty . you need to check on the +5 to the processor, check the 5 volt regulator and if possible check for the crystal OSCillator working. If you are able to check the waveforms it will confirm the processor IC.
Oct 10, 2011 | Sony DAV-DZ260 Theater System
Need a code to unlock our blaupunkt car 2003 car radio in a vauxhall agila
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
Apr 23, 2011 | Car Audio & Video
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Turned on system. it shut off. tried to turn it on again the display screen lit up and went out now i get nothing.
If every segment on the display lit up it will need a display driver IC (pain in the a## to replace need to remove the display to get at it) and it will also need a transistor in the power supply.
Feb 10, 2010 | Samsung HT-Q70 Home Theater System System
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
Dest error message
DEST Error is problem caused by an IC in DVD Processor Board. If you want to replace IC yourself, let me know Home Theater Exact Model Number and IC can be provided on charge basis.
Jul 27, 2008 | Audio Players & Recorders
BEST ERROR
You right, it calls "DESTination ERROR". You need to replace an IC in DVD Processor Board. If you technicalities of IC replacement, IC can be provided on charge basis.
Jul 27, 2008 | Sony Dream System DAVDX155 Theater System
Set dead
That code always be for audio amplifier IC damaged.Change it
Jul 09, 2008 | Panasonic Home Theater System System
F61 on SA-HT545
I can not find a listing for model SA-HT545. All I can suggest is that there should be a large black IC attached to a heatsink that should be marked STKxxx or something similar. Post that marking here and I'll confirm that it is the correct one to replace. That part is the output amplifier pac and is the most common failure part that generates the symptom you describe.
Keep me posted.
Dan
May 25, 2008 | Panasonic Home Theater System System
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
