I need MAC drivers for Samsung SCX 1480 multifunction print/scan/copy
melnavz
  • 1226 Answers
SOURCE: drivers
hello,
Here is your driver: http://www.samsung.com/ph/support/productsupport/download/Model_Select2.aspx?type=&subtype=&model=SCX-4216F&fileType=DR&LSSI=/ph/module/ssi/left/lmenu_printer_multi_functionproduct.sec&RSSI=/ph/module/ssi/right/rmenu_printer.sec
i am sure this solve your problem about this printer.
best regards, fixya melnavz
Posted on Feb 26, 2008
flopez
  • 161 Answers
SOURCE: SCX 4100 scanner problems
In the SmartThru application, find the devices connected list (usually on the upper right corner at the main screen). Select the SCX-4100 from the list, since this software will work with many scanners. After selecting the unit, close and restart the program.
Be blessed.
Posted on Nov 07, 2008
crayzeetrayn
  • 837 Answers
SOURCE: the driver of Samsung Scx-4Z16F printer
Here it is
Posted on Jan 18, 2009
  • 11 Answers
SOURCE: Samsung SCX-4725FN - why won't it scan
You have to scan through your computer printers/scanners area. I had this problem, too, but that seemed to fix it for me.
Posted on Jun 09, 2009
SOURCE: Need a printer driver for Samsung SCX-4720 for apple mac
OK, this answer might actually help you!
We just had the same issue with the same printer on 10.6.
Make sure all your OS updates are installed and then go to add a new printer in System Preferences (Printer and Fax section) and hit the "+" button.
If your printer is plugged in and turned on you should see it as a USB printer in the window that pops up.
Select (click on it) that printer one time and then click on the auto select driver drop down and choose to select a driver. Choose the following driver "Samsung ML-6100 - Gutenprint v5.2.3" and hit add. This driver fixed all of our problems.
No thanks to the USELESS Tech Support of Samsung. I despise companies that don't give a **** about supporting older products! Sorry, I'm in a bad mood!
Posted on Feb 10, 2010
Fail to scan from printer to pc
hi, please re install the printer driver full version for support the windos 7
Mar 25, 2014 | Samsung SCX-4729FD Multifunction Laser...
SCAN FROM PRINTER TO PC
pleas re install the printer full version driver
Samsung scx 3405F reset chip
Is There Anybody to solve my problem? My Problem Is "Reseting Samsung SCX-3405f Multifunction Printer".
Feb 04, 2013 | Samsung Scx-3405Fw Wireless Multifunction...
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
May 15, 2011 | Samsung SCX-4300 Monochrome Laser...
I have a samsung scx-4824fn that is not copying or scanning. It produces totaly blank copies as if there is no document on the scanner. the scanner lights and moves properly to the end. Could this be...
Unisntall and re-install software it sud resolve the issue:
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/mono-multifunction/SCX-4828FN/XSA/index.idx?pagetype=prd_detail&tab=support
Apr 19, 2011 | Samsung SCX-4828FN All-In-One Laser...
I need a print driver for Samsung printer SCX 4720FN for Mac OS 10.5.8. Help!
hi
go to following link you will get your samsung printer drivers
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06010300&prd_mdl_cd=&prd_mdl_name=SCX-4216F
Oct 26, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Printer won't print
mac OS X 10.5.5 update disabled some printers.  you have to reconfigure the printer on your computer
Jan 30, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Requiring scanner software for samsung SCX-4216F printer
Dear Sir,
I have Samsung SCX-4216 printer. Printing, Xerox & Fax working is OK, but scan facility is not working because i missed the original software. please give me  a solution for get the original software or scan drivers.
With Regards
Mohan
Dec 27, 2008 | Samsung SCX-4216F All-In-One Laser Printer
209 people viewed this question
jasbo
jasbo
