Question about Samsung Wave 533 Cell Phone
No wifi ap found - Samsung Wave 533 Cell Phone
Where do I find my SSID#
The SSID is the identifier for the wireless access point (AP) you are trying to connect to. If the AP is broadcasting, the SSID should appear in a list of available WiFi connections when you enable WiFi in proximity to the AP. The SSID is not necessarily a number, it can be ASCII text, such as "MyAP1234" or "Linksys". You click on the displayed SSID you want to connect to and if it is encrypted, you will be asked to put in the password or access code. Some AP/routers have the SSID and access codes printed on a label on the bottom of the router. Otherwise you have to get them from the provider of the WiFi access. Some AP's don't broadcast their SSID's and you have to get both items from the WiFi provider and use your phone's connect process to enter the SSID and access code.
Apr 25, 2015 | Kyocera Cell Phones
Samsung corby ii- no wifi ap found
How to no wifi ap found?
Mar 15, 2012 | Cell Phones
Cannot connect to wireless connection.
can it see your wifi access point?
if it can see your wifi AP would remove the remembered details and set it up again using the "view avaiable wireless networks" option......if it cannot see any wifi then i would check its enabled, the hardware on/off toggle is set to on....
found a video showing you how to remove profile from laptop in XP...
http://www.youtube.com/watch?v=CDT0pLQfyvg
hope that helps
Aug 22, 2011 | Toshiba Satellite A55-S106 PC Notebook
Whenever i activate my wi-fi in my S5263 then answer comes no wi-fi ap found
make sure your are near a active WIFI device and that device is not hidden and you know the password of the wifi device . try once your have all the above things you will be okay!!
Jun 14, 2011 | Cell Phones
Gmna cara mengunakan Wifi di samsung star ini??
sir,please explaine your problem in english language.Sir,but I think you are eagarly waiting for instructions for accessing wi-fi on your samsung star GT-S5233 cellphone.So Sir,here is your solution-
1. tab on wifi icon.z 2. search for wifi ap by tapping on 'search' option. 3.If any unsecure wifi ap found,click on it. 4.enter the network key if ap is secured.
Dec 18, 2010 | Samsung Star GT-S5233 Cell Phone
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
I can't connect to the wifi even in taskbar it shows that wifi is connected and signal strength is also very good. mine is acer aspire 3680. please help. also tell how to install lan drivers.
Hi Dear. Verify DHCP or Manual IP configuration from AP/WIFI Router. Disconnect and Reconnect and follow IP configurations as mentioned in AP/WIFI Router.
Feb 26, 2009 | Intel D865GBF Motherboard
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
Samsung Wave 533 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
