Question about iRiver H340 MP3 Player
Need parts badly
Due to an accident, (nothing to do with me, but that's awhole other story) I cannot charge the unit except thru USB. Is there anywhere I can buy the yellow plastic charger 'yolk' from inside the h340 & also I have now lost the charger. So anywhere that sells electronic parts & anywhere that sells chargers? Cheers
  • 147 Answers
Try This http://www.ipodparts.com
Posted on Jul 20, 2007
SOURCE:
I have audi a5 2015 model coupe. Car steering box damaged due to accident current number is 8KO 909 144 P . But in market same number not available 8KO 909 144 B E G dats number available if i fixed that...
You need to consult an Audi dealer to interpret the part number suffix.
The part number is the same but the suffix is different and often that could mean the item is identical but from a different manufacturer or that it is a reconditioned unit instead of a brand new unit.
Often new units are not available from a dealer except by special order for warranty purposes and for all other purposes a reworked unit is the usual replacement.
It almost certainly will need reprogramming...
Feb 18, 2018 | Audi Cars & Trucks
New shark battery xb617u won't charge
The battery probably failed due to lack of periodic charging.
May 24, 2017 | Shark Vacuums
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
Have samsung flight A797 that has a short in the USB jack. Will not charge and will not show unit as charging. What is causing the small black chip located on top of the circuit board below that USB jack...
the short is causing the over heating. there is most likely nothing you can do but get a new phone. get the usb jack replaced (cost about 30-50 bucks) from your phone provider
Mar 23, 2011 | Samsung Cell Phones
My walkman will not charge. I left it on charge
Hi joanna,
It is probably not turning on due to extremely low battery. Have you been using it for quite a few years? Then there may be a problem with the battery. But before that, please try connecting the player to another USB port on your computer, or removing any USB extensions except what SONY provided, or upgrading your USB driver. If nothing works, I'm afraid you'll have to refer it to a service center.
Oct 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Lens error and camera battery not charging.
SORRY TO SAY, BUT I AM READING HORROR STORIES ABOUT THIS MODEL OF CAMERA AND IT'S CHARGING OR LACK OF CHARGING SYSTEM. IT SEEMS IT IS A MAJOR PROBLEM WITH THE M853 AND ABOUT THE ONLY SOLUTION PEOPLE ARE FINDING IS USING A SEPARATE CHARGING BAY. IT SEEMS THAT VISTA HAS A POWER MANAGEMENT SYSTEM ON USB PORTS THAT TURNS OFF THE POWER ON UN-USED USB PORTS AND THAT IS WHY THEY ARE NOT CHARGING. YOU NEED TO GO INTO THE USB PORT SETTINGS AND RIGHT CLICK THEM AND DISABLE THE SETTING THAT ALLOWS THEM TO SHUT DOWN POWER TO THE USB PORTS. IT ALSO SEEMS THAT THERE IS A LOT OF TROUBLE WITH THE MAIN BATTERIES IN THE M853 FROM THE VERY FIRST TIME YOU TRY TO CHARGE THEM. THEY SEEM TO NOT WANT TO TAKE A CHARGE. I KNOW ALL THIS IS BAD NEWS BUT GO TO GOOGLE AND PUT KODAK EASYSHARE M853, NOT CHARGING AND READING THE STORIES FOR YOURSELVES. THEY ARE NOT PRETTY. BEST ADVICE I CAN OFFER IT SEEMS IS SEPARATE CHARGING STATION AND DEDICATED USB PORT YOU KNOW IS HOT. GOOD LUCK ON THIS ONE. IF THE CAMERA IS FAIRLY NEW, I WOULD CONSIDER RETURNING IT! THIS ONE HAS A REALLY BAD TRACK RECORD. IF I CAN HELP MORE, REPLY TO: ARCLIGHT1217
Nov 05, 2008 | Kodak EasyShare M853 Digital Camera
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
My GPS won't turn on.
I had this issue also. When I got it out of the box, it had maybe 30 minutes of playtime without a charge before the battery went low. I used the USB it came with and found plugging it into my laptop AND desktop does absolutely nothing; even though the magellangps.com states the USB can be used as a charger on the PC.
It's been less than 8 hours since I've had it, and I have not gotten a chance to use the car adapter to charge it... I have a DC/AC unit inside my house which I am using to charge the unit and it works fine (incase you dont know what a DC/AC adapter is; its pretty much a lighter adapter that plugs into the wall).
MAKE A LONG STORY SHORT -
With my migraine starter experience with charging and powering on; I have read on 100's of Magellan 3250 reviews that cold tempratures cause these issues.
Other possible causes:
Battery is 100% dead = leave it in your car charging (HIDE UNDER THE SEAT!)
If the USB port plugged in charging in the car; if it is still not working, make sure that the FM part is also plugged in. I found that my GPS does not charge with just the USB end plugged... At least for me, it will only charge with BOTH ports plugged....
I hoped my novel helped... If it didn't; return your Magellan, and buy a GARMIN GPS. I have a Garmin that I bought for my hubby, and 2 years later, has never once experienced any issues.
May 09, 2008 | Magellan Maestro 3250 GPS
How to
You should be able to charge the unit from the computer by plugging in the USB cable that came with it. The unit should then turn on and show an icon of a GPS attached to a computer tower. It will charge while this occurs. If nothing happens when you do this, perhaps your USB cable is bad. Does the unit work normally otherwise?
Mar 31, 2008 | Garmin StreetPilot c550 GPS Receiver
iRiver H340 MP3 Player Logo
74 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
