Cmd is not working
In my computer when i run the cmd in run options it will displat"windows cant find the cmd,make sure the name correctly"
  • 156 Answers
CMD Might not working because of any of the following reasons.
1. cmd.exe not available in Windows\System32 folder
2. cmd.exe might be hidden in Windows\System32
3. current user might not be having permissions to execute cmd.exe
Solution:
1. search cmd.exe from local disk or installation disk and copy to windows\system32 folder
2. Right click cmd.exe and remove system and hidden attribute
3. Change the permission for cmd.exe to read and execute
Hope it will work, if not please call me 9899780221
Thanks
Zulfikar Ali
Posted on Jan 27, 2009
Receive message "Folder in your mailbox have name conflict". Not sure what that means nor how to correct. Do not understand instructions.
What mail client you have is saying that there is more than one folder like "inbox" etc that have the same name.
Apr 21, 2017 | Computers & Internet
Tip
Windows 7 not Genuine
Ever had the Window 7 not genuine above.
You can simply solve that problem without any crack or hacking. any on without much pc knowledge can do this by following the simple steps below.
DISABLING WINDOWS UPDATE
  1. First make sure windows update is off (that is what caused the problem)
  2. Right click on the "my computer icon"
  3. choose "properties" from the context menu
  4. Look for "windows update" on the left hand side of the displayed property box and click on it
  5. from the next user interface look for the change settings and make sure windows update is turned off.
  6. NOTE: THE ABOVE STEP IS NOT REALLY NECESSARY BUT A PRECAUTIONARY MEASURE TO AVOID FUTURE ISSUES AGAIN.
NOW TO THE MAIN WORK
  1. Go the "start: menu and click on "run", if you do not find it simply hold down on the windows logo key on the key board whiles you press r on the keyboard.
NOTE: YOU CAN ALSO JUST TYPE "cmd" without the quote into the windows 7 search box. You should get only a single result since it is the only file in windows with such a name. Right click and choose "run as administrator" and follow step 3 below.
  1. From the small box type "cmd" without the quotes
  2. NOTE: YOU CAN ALSO TO GO THE C/WINDOWS/SYSTEM32/CMD right click on the cmd file and run as administrator if you find issues.
  3. type slmgr -rearm and press enter
  4. wait for the confirmation massage and restart the windows.
  5. YOU ARE DONE
on Aug 03, 2011 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
What do I have to press for it to be command prompt, because I'm not sure?
open cmd run-> Cmd or you can run the dos one by creating a shortcut the shortcut name is command.com
cd ( command)
for ex: cd/ gets u into the main hard disk page
dir to make your cmd read files and info that hard disk contain
other ex: when you dir the file yo can enter them by this command
cd File Name
ex 2 : cd program files
that will get you into program files
Ex3 aND its the most IMPORTANT To Change the hard disk ( the hard disk were you are ) Hard disk Name:
Ex 4 there is a way you cant write and save your reminders etc.
By Typing edit
a window will pop up
Hint You can write help to get all of the commands can use
I Hope its helpful
Jun 15, 2013 | Computers & Internet
WANT TO AD RAM
Step 1:
windows 8 upgrade b> Run the Windows 8 Upgrade Assistant :
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8. Note: To make sure the system is compatible visit http://windows.microsoft.com/en-US/windows-8/system-requirements. http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8 b> When making significant changes to your computer such as an upgrade, it is always recommended you backup your system prior to installing a new version of Windows. Thankfully, all editions of Windows 7 includes system imaging, which means you can backup your entire Windows 7 installation and restore it if it fails. Learn more about how to backup your Window 7 installation here In addition to System Imaging, you can backup just your personal files using Backup and Restore, to do that, check out the following article: http://notebooks.com/2010/12/27/how-to-backup-to-an-external-hard-drive/
http://notebooks.com/2011/02/25/how-to-restore-a-backup-from-an-external-hard-drive-in-windows-7/ If you want to backup themes, wallpapers and other minor features, Windows Easy Transfer is another option, you can learn more about it here What you can do before attempting the upgrade? You can do some pre-requisite tasks to ensure a smooth migration from Windows 7 to Windows 8. If you are using a name branded computer such as a Dell or HP, go to the manufacturers website for the model computer you are using and download the latest available drivers for that computer. Store them on a disc or USB thumb drive. Important drivers you should try to obtain include Network and Video Drivers. Its possible that they might just have Windows Vista or Windows 7 drivers, those will work with Windows 8. Other things you can do: Uninstall any security software before attempting to upgrade. Disable any encryption software you might have installed. Disable/uninstall disk utility software such as DVD/CD burning utilities or third party defragment programs such as Perfect Disk. Make sure your computer is updated (devices and applications). Disconnect any external devices before installing. Check your hard disk for any errors:
- Click Start
- Type: CMD
- Right click CMD then click Run as administrator
At the Command Prompt, type: chkdsk /r /f
Exit the command prompt.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them. Another thing you can do is disable Start items: Click Start Type: MSCONFIG. Hit Enter on your keyboard On the General tab, click Selective Startup. Under Selective Startup, click to clear the Load Startup Items check box. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All. Click OK. When you are prompted, click Restart. After the computer starts, check whether the problem is resolved. Run the System File Checker utility. SFC/Scannow checks your Windows installation for errors and corrects them. This will help with ensuring that a smooth upgrade occurs. Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: sfc/scannow This will check for any integrity violations Restart your system
Feb 06, 2013 | Computers & Internet
My avent 7109b laptop was asking for password when it boots up but cant remeberwat it is after 3 try it say system diabled and the code 036501 can anyone help me please
You can reset the password of Windows 7 and Windows Vista. These steps are not provided as troubleshooting. I m jus curious to help you out with my experience.
insert the disc and boot to WinRE
Boot to Win RE
Click Command Prompt option.
C:
CD Windows\system32
ren cmd.exe cmd.old
ren magnify.exe cmd.exe
ren cmd.old magnify.exe
Restart computer
Click on Easy of Access centre left side bottom ? Choose Magnify option ? Command prompt opens up
Type: net user administrator /active:yes
Restart the computer
Logon on administrator account and then using User Account page, remove password for the other account
Search for Magnify.exe in start search and click on it
Type: net user administrator /active:no
Boot to winRE
Type the following:
C:
CD Windows\system32
ren magnify.exe cmd.old
ren cmd.exe magnify.exe
ren cmd.old cmd.exe
exit
Restart the computer – system logs on to the User account without asking for password provided there is only one user account.
Mar 07, 2010 | Computers & Internet
How do you change the network name for a 120N?
You need to login to you router. If you're not sure how to do it, do the following.
1. You need to determine the default gateway: press the windows + 'R' button and type in 'cmd' or alternatively, click start, run and type 'cmd' and hit enter. Once the command window has opened, type ' ipconfig', and what we want is the default gateway address.
2. Type the default gateway addres into you browser and login (if you're not sure what it is or if you've forgotten it, you will need to reset the router.
3. Once you have logged in, you need to select wireless, and then basic wireless settings. You will see and option 'wireless network name (SSID). This is the option to change the network name!
Jan 26, 2010 | Linksys WRT120N Router
Forgot password
Steps :
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
When you log in sign in to name with password that was forgotten and change to one that is known.
Sep 27, 2009 | Toshiba Satellite L305D-S5934 Notebook
Windows live messenger sign in error code 81000306
That means Windows Live Messenger is unable to contact the authentication server.
Open up Live Messenger and go to Tools and go to Options. Under Connection Settings, choose Advanced Settings. Make sure there are nothing in the proxy fields. Make sure the SOCKS area has nothing in it and click okay until you get back to the Messenger window and try to sign in.
If that doesn't work and you are running Windows Vista, click start, type: cmd, right-click cmd.exe when it appears under Applications, click Run As Administrator, type the following: "netsh int tcp set global autotuninglevel=disabled", rress enter, restart your computer”
Hope this helps!
Oct 18, 2008 | Computers & Internet
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
