Question about HP Pavilion a705w PC Desktop
Replace motherboard Hp a705w
First off I have to press the some button down on the motherboard for my computer to start or else it wont start i dunno why its like that, and second of all when I start it up after the computer counts up the ram it tells me this
162- system options not set
and then when i press F1 to save the settings (which I have to do everytime i start up the computer) it sends me another message that says
219- ECC memory module detected. ECC modules not supported on this platform..
HELP
  • 4 more comments
  • csj2085 Jan 27, 2009
    This is what I found..my old board supports DDR1
    My new one supports DDR.
    I was told by the people that I got the board from that the ram I had would work...how would I know by looking at my ram what one I have..???
    Well I just left a computer service place and was told this....Here goes
    D530Sff Code
    Card Bios updated
    Also that the motherboard is for a compaq
    It maybe compatable..Heck I don't know...
    I'm waiting on response from company I got the board from..
    I'll keep you posted
  • csj2085 Feb 24, 2009
    I no longer have it.....Junked it...Thanks for all the help ppl.
    Many thanks for all the help...I junked it
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Post the make if you know it, and any numbers on the module. They should be on a white sticker.
  • Wayne Mineard
    Have you recently installed new memory? If so, it appears you have installed the wrong kind. It should be non-ECC RAM.
    This is your RAM info:
    Two 184-pin DDR DIMM slots.
    Maximum memory size is up to 2GB, 1GB per slot.
    Supports PC2100 0r PC2700 unbuffered non-ECC
  • 51 Answers
Techguru2009: First you need to disable the ECC memory module in the BIOS settings. Don´t know what button you are talking about on the motherboard. Check your manual for the motherboard to see what that button is for.Careful how you change your BIOS settings OK. You might want to load defaults first to see if that helps.
Posted on Feb 24, 2009
Logs on and than suddenly logs off
Look on your motherboard beside the bios battary you will see a jumper with 3 pins move the jumper to the last two pins for 5 second then put it back that should reset it
Jun 05, 2010 | HP Pavilion a705w PC Desktop
Reset BIOS on HP Pavilion a750w
Fastest way to reset BIOS is to remove the CMOS battery (looks like a large watch battery on Motherboard) for 30 minutes. After you replace the battery, the BIOS should reset to default. If further problems arise involving the BIOS, it's possible the CMOS battery is bad.
Dec 13, 2009 | HP Pavilion a705w PC Desktop
My HP a705w is stuck on the blue logo screen.
1)unplug all the peripherals from the computer,press the power button and hold it,then connect the peripherals.
2)open the tower and try to reseat the ram and the memomy slot.
3)try to go to BIOS screen,if it gets stuck while going to bios,shut down the computer,disconnect the sata cable of the harddrive,try to boot the computer to bios without the hard drive connected,if it goes to bios properly with the harddrive cable disconnected,that means hard drive has gone bad.motherboard is alrite.
Oct 12, 2009 | HP Pavilion a705w PC Desktop
My HP Pavilion a6037c desktop PC is stating there is system failure. Please help! I am a distance learning college student along with my wife and we both need the computer to complete our courses.
please check the RAM Of your computer
Just Open the cover , Removew the RAM , Clean the ram connections and then press every connection of hard disk, motherboard and power supply.
Oct 05, 2009 | HP Pavilion a705w PC Desktop
I have an hp a705w it wont turn on the light blinks
The Power Supply Might Have Gone Bad, or the motherboard could have loose connectors on it/be worn out. If It Is Still Under Warranty Have It Diagnosed. Does It Beep At All?
Aug 20, 2009 | HP Computers & Internet
Mother board wont power up
If you have another Socket 478, you can probably use it with your CPU. This is not a guarantee, but in my experience, it should work. If you come up with one, you can probably check the specs on the manufacturer's site to make sure it will support your components that are in the present board. Sure worth a try. One problem is you might have to do some case mods to make the other motherboard fit. Many of the manufacturers get their boards and cases custom-made.
May 04, 2009 | HP Pavilion a705w PC Desktop
I have a hp pavilion a705w bout 12-30-04 it wont boot most times
That's because it has a failing power supply. I post this a lot. Why? Because 70% or more of computer failure, is directly related to the power supply. Next up is Electrolytic Capacitor failure on the motherboard, (The 'Caps' that surround the processor, more specifically. These are Voltage Regulators for the processor)
Then harddrive failure.
Many times you'll see a solution posted to use a Restoration disk, or System Restore. This is just a 'Band-Aid' approach. The power supply, for you, is the problem.
Apr 12, 2009 | HP Pavilion a705w PC Desktop
Computer won't come on but the power supply in the back does.
try unplugging the power, holding down the power button for 10 seconds, then plugging it back in and pushing the power button. If that doesn't work, try replacing the power supply.
Mar 25, 2009 | HP Pavilion a705w PC Desktop
I had the same problem, I unplugged my computer to move it before it had fully powered down. It wouldn’t start and all I got was the flashing lights.
I asked a friend who suggested I remove the power to the motherboard then reinsert it while it’s hot. Here’s what I did. Unplug the computer. Touch something metal so you’re grounded and don’t create a static shock on the motherboard. Now GENTLY pull the 16pin wire harness off the motherboard. Now plug the computer power cord back in. Then GENTLY plug the motherboard back in. With any luck the fan will start up and the computer will begin booting up. It seems to be some type of problem where the power supply doesn’t recognize the motherboard so it doesn’t do anything until it “sees it”? Probably some type of a safety to prevent motherboard burnout?
Oct 20, 2008 | HP Pavilion a705w PC Desktop
HP Pavilion a705w PC Desktop Logo
715 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
