Question about Bowflex Treadmill Series 7
Calibrate fail with Bowflex series 7. What next?
5 Suggested Answers
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
  • 49 Answers
SOURCE: My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Posted on Aug 31, 2009
ercupa190
  • 12223 Answers
SOURCE: incline motor is not working
Dear Sir:
1) If everything is working , now the only thing you can do:
2) check the Motor Lift the Voltage DC ( direct current) is diffferent from the Motor Drive that work with 115 VAC( Voltage alternating current). See the Voltage in the plate of the Motor if 48Vdc or whatever voltage is indicated.
3) Check the breaker and reset , and clean with solution with 50% oxigened water and 50& ethilic alcohol (100%).
4) If all is clean, turn on the motor Lift, and See if there are voltage and the terminal Motor( Check with VOM-Voltimeter in the range DC,) .
Check again the voltage indicate in the plate of Motor, if the Motor is NOT Working, the Motor is Bad( Some brushes wear, and winding overheating) replace or repair.
Conctac me, if you need some additional Help.
sincerely.
Have a great time, blessing.
E.CUADRA
Posted on Sep 05, 2011
nikhil120901
  • 38 Answers
SOURCE: belt and incline not moving on bowflex series 7
replace it
Posted on Jan 21, 2012
How to recalibrate a bowflex series 3 treadmill
Plug power cord into wall outlet and turn on power switch. 2. Stand on the side foot support platforms or rubber floor mat. DO NOT STAND ON THE WALKING BELTS. 3. Insert the Safety Key. Note: The Bowflex if the Safety Key is not fully inserted into the safety keyhole. 4. Press and hold hold "ENTER" and "POWER" for 3 seconds while the Console is dormant. The word "CAL" shows on the display. 5. Press "START". This enables display of maximum speed (with unit of measure) and maximum incline. 6. Verify correct units of measure (English imperial/ metric). Press "START" to change from one type to another. Press "ENTER" one time to set the measurement unit. 7. Press "START". 8. Press "POWER" again to save and exit, once calibration is complete
Oct 21, 2016 | Bowflex Exercise & Fitness
Errors for Bowflex series 7
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 27, 2016 | Bowflex Treadmill Series 7
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Calibration fail message on bowflex treadclimber.....help
Jun 03, 2009 | Bowflex Treadclimber
Bowflex treadmill code 05
tHIS MAY BE A SPEED LOSS ERROR. Is the belt moving when this happens? Decribe what lead to this problem in the first place that will help me to better assist you.
Mar 30, 2009 | Bowflex Treadmill Series 7
Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Feb 21, 2009 | Bowflex Treadmill Series 7
Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Dec 25, 2008 | Bowflex TC3000 Treadclimber
Bowflex Treadmill Series 7 Logo
65 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
