Question about Boujer MQ998 Quadband Watch phone
"file error, reset default" for MQ998
When i turn on this phone, came text "file error, reset default" .. what i suppose to do.. thanks
DO I NEED A SIM CARD FOR MQ998 CELL PHONE WATCH
Yes, a SIM card needs to be purchased separately to use the cell features of the watch.
I hope this helps.
Mar 24, 2013 | VIP-Top Sales Watch Phone MQ998 Cell Phone...
Phone froze texts stopped going through then when I went to turn off it acted like it was shutting down but the display is frozen showing Verizon red check mark on a white screen..... the phone won't...
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is confirmed that the software has errors and will need a reinstallation. Please check on the message list if there was any suspected messages received , if so delete them all and reset phone to default factory settings as the last resort.
Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Thank You for using Fixya
Sep 01, 2011 | Samsung GTC3300 Cell Phone
I cannot send text message for my E63,but i can received text messages and make a call,whenever i tried to send a message it always say failed,and memory full but i already erase some of my files
first do a back up all your files in your phone and make a reset or restore it into factory default and also reformat your external memory or your memory card, i can assure you your that your problem is solve......
Aug 04, 2011 | Nokia E63 Cell Phone
I have a motorola v3..it worked well for the past years.but suddenly whenever i compose a text message my phone starts to hang up and its stuck... i tried to shot it down and turn it on once again...it...
The phone stuck due to this instances
Phone memory is low that's why its getting stuck,it means,not enough memory may cause malfunction.
Solution are :
* delete unused data or files so there will be a free space on your phone memory and to be able to operate smoothly.
* Reset the phone by this procedure,go to settings > initial set-up > Master Reset or Master Clear
Master Reset - your phone settings will go back to default (no data will be deleted)
Master Clear - your phone setting will fully format. (all data of yours will be deleted) and back to original settings.
before doing master clear,be sure all of your important data must be saved before doing this method.
I hope this solution will help you. thank you for visiting fixya.
Jun 17, 2011 | Motorola Mobility RAZR V3
I can't put my greeting on my machine
First of all reset the phone using the default codes to set the phone to factory settings . Now open settings to set the text/tone on start up. Also reset the phone to see if there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
May 11, 2011 | Cell Phones
Error message says "An application
I have this phone, you should be able to call your provider on another phone and have them do a hard reset which sets it back to default factory settings.
Good luck
Mar 25, 2011 | LG RUMOR Cellular Phone
My phone is showing an error message "3d010017"
hi , To fix the error , please reinitialize the software of ur mobile . i will give u the step
    1. While in standby mode, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Reset Settings (8)
    4. Press the OK button to check the box(es) for the following:
      • All: Phone, Display, and Sound settings will be reset to the default values
      • Phone settings: Only the Phone settings will be reset to the default values
      • Display settings: Only the Display settings will be reset to the default values
      • Sound settings: Only the Sound settings will be reset to the default values
    5. Press the left soft key for Reset
    6. Press the left soft key for Yes to reset the handset
    7. Enter the password, using the keypad, default password is "00000000"
    8. Press the left soft key for OK to reset the handset
    For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 15, 2010 | Samsung SGH-t219 Cellular Phone
How to format samsung star s5233
*2767*3855# this code will format your phone so please create backup of your files before doing this
plz click on 4 thumbs below and click on YES if helpful.
Nov 08, 2010 | Samsung Star GT-S5233 Cell Phone
Error code 453 invalid number when turning phone on
take the phone to a mobile service center and have them reflash the keypad flash file back into the phone.
Jun 14, 2008 | Motorola Mobility RAZR V3
Boujer MQ998 Quadband Watch phone Logo
Top Boujer Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Boujer Cell Phone Expert? Answer questions, earn points and help others
