Question about Gigabyte GA990XAUD3 AMD 990X AM3 ATX Motherboard
Stock AMD FX fan won't install
The stock fan won't install. The instruction manual doesn't even show the correct picture that look like the latches. I'm able to fit one of the two latches, but there is no way the second will fit, it's way too short.
  • Gigabyte Master
  • 3,606 Answers
Hello you can download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=3901#manual
You will need adobe reader, to read the content.
Here should be a good picture, how to install the fan.
Maybe the fan is wrong, and don`t force it to fit.
And remember to apply, some thermal grease.
Here is a youtube video, that shows how:
http://www.youtube.com/watch?v=MzZQgJDyzGI
Best of luck :-)
Posted on Jan 22, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: prosser overheating with stock intel
Power supply?
Posted on Feb 13, 2011
Recently ntly bought a new processor fx 6300 AMD
Could be a cable routing problem; interfering with other cables . Try re routing/separating the loom.
Oct 27, 2013 | AMD FX Six-Core Processor Model FX-6300...
Stock password in preferences? Won't play movie without a password.
The default password is 3308. If this doesn't work I suggest you do a factory reset on the unit. See page 28 and 29 of the manual.
Oct 26, 2012 | Philips Magnavox MRD-250 System
Fan ventilator doesn't stop
fan relay stock, fan hot wire to battery
Aug 22, 2012 | 2008 Nissan Versa
Weider club C650 assembly manual
There are multiples versions of the Club c650 - check your model number. Here is a user manual for the WEBE37340 CLUB C650.It comes with assembly instructions.
Here is one for the WEBE37770, but it doesn't look like it's in stock.
Apr 04, 2012 | WEIDERFITNESS.COM Weider Club C650 Smith...
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Big tire places, Costco, BJs, Sears etc do not stock tires in the original equipment size of P185/60 r15. They stock P185/65, and P195/60 which seem very close. But Costco (at least) refuses to mount any...
The vehicles electronics is set up for what came
with it
You won't have ABS Braking System or Speed
etc ,work correctly.
There is a list of things,but that is a couple
It is no different now than 40 years ago
The fact people that have always done what they
wanted with their vehicles, doesn't mean it
was correct or they had any knowledge whatso ever
Jun 29, 2011 | Scion xA Cars & Trucks
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help...
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
Oct 15, 2010 | Dynojet Cycling
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Gigabyte GA990XAUD3 AMD 990X AM3 ATX Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
