How to reset sharp AR-5620sl - Office Equipment & Supplies
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 32 Answers
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Posted on Apr 17, 2010
  • 3 Answers
SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
Posted on May 18, 2010
  • 990 Answers
SOURCE: sharp ar 5516 maintenance reset
Hi sir; press 4-key as follow by order "#, interrupt,C, interrupt " then enter 20 then01, repeat 4-key again then enter26, then enter 36 press1
Posted on Sep 02, 2012
Cogz
  • 1326 Answers
SOURCE: Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Posted on Jan 14, 2013
Sharp ar-5620sl, how can i do when error code h4 displyed?
you need to reset the error its telling you that your fusing unit is not ok
Jun 01, 2016 | Sharp Office Equipment & Supplies
Total counter reset program for sharp ar 5618
Can not be done. people then would reset the counters on old machines and sell them as new
May 16, 2015 | Sharp AR-5320 Black and White Copier
What type of developer is used in a Sharp Ar 5620sl?
Developer is changed by a technician. not customer replaceable.
Mar 31, 2015 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
133 people viewed this question
jasbo
jasbo
