Question about Fuji FinePix S20 Pro Digital Camera
File no. full - Fuji FinePix S20 Pro Digital Camera
What is the problem on recording my fourth record, the screen indicates FULL. What is the next step. Thank you
When you say "fourth record" do you mean 4 LPS containing at least 16 tracks each?
If you are, check the format that the recordings are in. For example some recording software use WAV files which are very large.
Since an LP is about 30 minutes a side maximum you could have two hours of music! Depending on how full you drive was it could be nearly full, especially if they were recorded as WAV files!
MP3 files take up far less space so you could convert the WAV files to that format and then delete the wave files. If you can free up space to do it.
Jun 25, 2016 | Audio Players & Recorders
EG DATA FULL
Hello
The hard disc have full. Just delete some unimportant files from it. If any video files have been stored, and is not important delete them. video files will take more space than any other data files.
Feb 04, 2012 | Computers & Internet
My 5800musicexpress phone momery is full so how can delete my phone momery
Hello there,
If your phone should come up with the message 'memory full' it simply means there are too many files on the phones memory and requires you to delete some so its memory space will be free.
shortcut To delete the files from your phone memory i quite simple. All you have to do is try to snap a picture using the camera, it will tell you the phones memory is full and ask if you want to delete some files, then it will show you the files to delete from, either picture files, videos or songs, then you navigate to the file you want to delete and select and delete then.
Then there will be free space on the phones memory.
Thank you for using fixya.
caseytech
Jun 27, 2011 | Cell Phones
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
When placing DCS2 files into a picture box the preview displays as a pixalated lo-res image. Tiff files are fine. The preferences are set to full resolution previews. Is there a way to make DCS2 files...
Looks like you would be better off just converting to tif files. Quark apparently has a problem with these type of files. You can try saving as Multi Channel. Make sure you set the preferences to Full Resolution Preview.
Nov 27, 2009 | QuarkXPress 7 Full Single User Mac/Win...
8x10 inch pictures transfer to Photoshop as 9x12 centimeters
open them in some like window pic manger and change the size there then after that up load them to your photoshop
Jun 01, 2009 | Sony Cybershot DSC-H3 Digital Camera
USB Flas Drive - Files disappeared
In the explorer make sure you can view hidden files. (Tools>folder options)
Check the file sizes of each file by mousing over. Add them all up manually. Is this the size of the disk ?
If the total size is not the full storage size copy over to the PC> format the drive and drop them back on.
Dec 15, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony 256k micro vault 2.0 drive says it is full
Hi-
Right click on the drive in your computer, go to properties. Unchecked hidden files then click ok. or open the drive for USB click on view on the toolbar, click options or folder options, check show hidden files. then delete the temp files.
Hope this helps, pls dont forget to rate solution.
Oct 20, 2008 | Sony 256MB Classic Violet Micro Vault USB...
File copy error.
maybe your drive is already full, if your drive is already full try to delete the temp file or delete your unnecessary files, if not try to check the file that you are trying to copy, maybe there some associate file which have a long file name, try to rename it but copy first the original file name to notepad, and after copying rename again your file that you renamed before, if still not tell us what kind of file you want to copy.
Sep 08, 2008 | Computers & Internet
Fuji FinePix S20 Pro Digital Camera Logo
16 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
