Question about Cycling
My Huffy Rock Creeks left crank is really loose. Looks like its missing a spacer or something. Where do i get one?
    Problem Solver:
  • 18 Answers
This is the side with out the chain ring, it should use a Allen wrench or socket wrench. if this is a mountain bike or road bike a crank arm it usually takes a crank breaker tool to remove arms so if it is loose it sounds like it should be replaced. anyway if it does come off, clean it with any cleaning solution and put grease on the bottom bracket<if you don't have grease you can use Crisco or petroleum jelly> put crank arm back on and then tighten bolt back. this is for a three peace crank, if it is a one peace then its a matter of tightening bolts.
Posted on Jan 25, 2013
3 Suggested Answers
  • 29 Answers
SOURCE: My Mens 26" Huffy Rival
well i would find out what size it is, then head down to the industrial store and by a tap and dye set it comes with various sizes and the handle. tap it out and give it a try. if still to loose then wrap it up with a little tape. now if its real bad just buy a new crank.
Posted on Jul 11, 2011
SOURCE: How to raise the handlebars on a 20" Huffy Rock It
Usually there is a hex bolt or some kind of bolt in the handlebar stem.
Loosen the bolt 4-5-6 turns.
Bolt will move upward.
Then hit bolt down with wrench.
Handlebars should be loose.
Raise handlebars to position.
Hold bolt upward with fingers while tightening.
Posted on Dec 25, 2010
How to fix my huffy rock it bicycle
Sounds like you may not tightening it down tight. should have about 1/2 play in it. If that dont do it you might look at the sprockets ( bent or missing teeth ) or may need a new chain. Hope that helps you. Good luck. Vern
Apr 30, 2014 | Huffy 20" Rock It Boys Bike, Black/Orange
I tried aligning the doors by by adjusting the screws and hinges the equipment is level but the door still hits i saw something about the Styrofoam but how do i fix this
You may have a warp liner. This can happen if off for a while. And left open. But really sounds like a bent hinge or missing a bushing/ spacer. Would be nice to have a model number so I could be sure. I hope this helps.
Aug 24, 2011 | Refrigerators
Crank is loose
http://www.parktool.com/blog/repair-help/categories/crank-service
Or you could have simply done a web search for "loose crank" and found video help
Aug 11, 2011 | Huffy Cycling
Jul 11, 2011 | Huffy Men's Rival Bike Silver 26Inch
Dec 25, 2010 | Cycling
My son has the Huffy rock out bike. The pedal fell off, and so I was sent the whole single arm crank and new pedals. I have no owners manual, and no assembly instructions whatsoever. Along with the crank...
The reason the pedal fell of is because of a bad set up. Who assembled the bike? If, you did, guess what! You did not tighten the pedal to the crank arm to begin with. If, Walmart or other discount store did it, have them fix it. You have to understand. you bought the bike without professionals putting it together and sometimes that is a problem when you don't have the knowledge of what you are doing. You have to pay one way or another. When you let a kid ride a bike that is not assembled correctly you are endangering them. My advice is :Get it fixed right.
Sep 16, 2010 | Huffy Cycling
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
Cycling Logo
199 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
