Question about Westinghouse Refrigerators
White Westinghouse RTD16VM Frostfree fridge freezer has been making noise when motor kicks in and has now stopped altogether.
Motor is noisy and appliance has now stopped altogether.
kstfas
  • 75 Answers
SOURCE: Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Posted on Sep 29, 2006
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
watugot
  • 290 Answers
SOURCE: kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Posted on Apr 12, 2008
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
SOURCE: Maytag side by side fridge makes vibration noise
Mine is a different model, and less than three years old, but the vibrating noise was really annoying. I would shift the unit or the door slightly, and it would stop for a while, as you reported. I took a few minutes, applied pressure to different areas, up and down, inside and out. The noise was louder near the floor. I removed the plastic grill and applied upward pressure on the wires covering the coils - it was loose. I noticed an accumulation of dust, and vacuumed as far as I could reach around the underneath area; also pulled fridge out and vacuumed a dust-covered vent on the back near the floor. Was planning to insert some kind of wedge under the loose part, but when I put everything back in place, the vibration stopped - now I only hear a gentle hum. Seems I did something right in this process.
Posted on May 20, 2009
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
The motor on my frostfree fridge never stops running. Below the freezer isnt cooling. The freezer is cold but not freezing
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Mar 06, 2011 | Magic Chef CTB1722 Top Freezer...
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
Refridgerator make a noise every 3 minutes
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
I have a servis fridge freezer m7873.yesterday morning the motor became very noisy.by late afternoon it stopped altogether,and everything began to thaw.what do you suggest?
that motor noise if it is the compressor is not a good sign. You will need a service tech to inspect it to make an educated decision on what to do next. I would replace the freezer if it would be cheaper than the repairs
Nov 24, 2009 | Freezers
Significant fan noise on Westinghouse WSE7000W side by side
you need a new fan motor... the bearings are shot
Aug 03, 2009 | Westinghouse Refrigerators
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
78 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
