Question about American Pro VS1405 Car Audio Amplifier
American Pro VS1405
Okay so i have a American Pro VS1405 and it works really good until it gets super hot and turns off. I heard a cooling fan will help but would i put the fan inside the amp or what??
  • 3 more comments
  • sgates88 Jan 27, 2009
    Its 800w and my sub is 550RMS
    hmm idk where can i find that at??
  • blueextc3221
    blueextc3221 May 11, 2010
    Your subwoofer's make and model # and how many you have in service.
  • blueextc3221
    Load = resistance to energy flow.... not power.
  • blueextc3221
    What is the load on the amplifier?
    Sounds like you are over-driving it.
    Sniper:
  • 86 Answers
Sounds like the thermal protection on your amp is doing its job. You can put an external fan in to help in cooling, like the crossflow type shown here, or a couple of muffin fans like these (look familiar?). You may have fashion a bracket to mount the fan(s), but that shouldn't be too much of a problem. Many fans are shipped with mounting tabs attached.
Posted on Feb 13, 2009
Car started knocking really bad got a cylinder 2 misfire code after opening coolant bleed valve with enging hot
Okay, it may be due to overheating, that may be the noise you heard, lets hope. first allow engine to cool, open radiator cap or the resivoir cap, which ever is the fill, remove the bleeder at top hose and fill radiator slowly until coolant comes out bleeder.
note if water pump was replaced due to leaking and engine was overheated at that time then it may be a good idea to replace the thermostat .
after filling is done start engine and allow it to run. watch temperature if temp start to climb past half way shut engine down and let sit for 5min. then restart and check level, in res do not open cap . feel air from fan and see if it is getting hot, this may take up to a half hour but do not drive,
A few questions, does this jeep have an electric fan?
when you heard the knocking was engine temp hot?
If you start jeep cold does engine knock?
Did this jeep get a new thermostat with waterpump job?
did it overheat when pump went bad and why did water pump get replaced?
sorry for all the questions ,just trying to get all the info to help you .
Dec 25, 2012 | 2004 Jeep Grand Cherokee
My car is overheating
Hello, You did not indicate what vehicle this is. But in general, most cars have 2 water sensors. One makes the dash gauge work and the other makes the Electric radiator fan work. Check with a good Autoparts store like Autozone, Oreilys, or Advance for parts application. These stores will also scan your vehicle for free.
When you have an Electric cooling fan there are usually 2 speeds on them. When the engine is really hot(Overheating) and when the A/C is switched on, most will run on High speed. You can sometimes have only low speed and the car will be Okay until you get in slow traffic or use the A/C. There are Relays for the fan which turn on when the water sensor(remember there are usually two)activates them.
These are things to test. If the water temp sensor is working, if the relay for the cooling fan is working, or if the cooling fan motor is bad. Check the fuse panel for a blown fuse, but that only means there really is a problem that has to be fixed. It is the reason the fuse failed.
There is another type of cooling fan that has a "clutch" on it. It may be used in combination with an Electric cooling fan. The clutch is fluid filled and responds to air temperature. It is suppose to work really good in hot weather and coast(free-wheel) in cold weather.
Finally, clogged Catalytic converters can cause your problem. Your engine can build up heat because of them, but usually some kind of "Check" light will activate telling you something is wrong.
When you post a problem, remember to give the type of car you have.
Oct 26, 2011 | Cars & Trucks
IT KEEPS OVERHEATING
REPLACE THE THERMOSTAT AND RADIATOR PRESSURE CAP.IF COOLANT LOW, ADD MORE COOLANT THROUGH COOLANT OVERFLOW UNTIL COOLANT LEVEL IN THE COOLANT OVERFLOW STAY AT FULL COLD MARK.REASON POUR COOLANT THROUGH COOLANT OVERFLOW MOST GM CARS DONT HAVE RADIATOR CAP.WHEN YOU GET COOLANT LEVEL OKAY, CRANK CAR LET IT IDLE UNTIL ENGINE GET HOT BUILD UP PRESSURE THEN TURN OFF CAR.CHECK FOR COOLANTS LEAKS AT THE RADIATOR HOSES,CHECK FOR LEAKS AT THE RADIATOR, CHECK FOR LEAKS AT WATER PUMP WEEP HOLE IF YOU SEE COOLANT LEAKING FROM WEEP HOLE REPLACE WATER PUMP. IF CAR OVERHEATING WHILE IDLING YOUR COOLING FANS NOT WORKING CHECK COOLING FANS FUSE AND RELAYS.IF FUSE AND RELAYS OKAY THE ENGINECOOLANT TEMPERATURE SENSOR BAD.
Aug 01, 2011 | 1994 Cadillac DeVille
It wont get power
Check the primary fuse on the positive amp wire usually located near the + battery post. Also check any onboard fuses. If these check OK, make sure the remote lead has 12V+ on it when the head unit is turned on. If these all check out, the amp is most likely defective.
May 16, 2010 | American Pro VS1405 Car Audio Amplifier
Electric cooling fan not working?
SCAN CAR FOR A FAULTY COOLANT TEMPERATURE SENSOR.IF SENSOR GOOD CHECK COOLING FAN FUSE AND RELAY.IT BOTH OKAY.HOT WIRE COOLANT FAN USING JUMPER WIRES TO BATTERY IF FAN DONT WORK REPLACE THE FAN MOTOR.IF COOLANT TEMPERATURE IS BAD REPLACE IT.BECAUSE IT CONTROLS THE FAN TURNING ON WHEN COOLANT GETS A CERTAIN TEMPERATURE.
May 04, 2010 | 2001 Kia Sephia
How much rms dose an american pro vs 1409 put out
I used to have a similar model, vs1405, and it was advertised to have 600w max. Its rms ratings were 260w bridged @ 4ohm. and 80x2 @ 4 ohm.
So I really wouldnt expect much.
I would personally suggest the HiFonics Brutus. Very nice amps for the price, and have TONS of power.
Oct 26, 2009 | American Pro Car Audio & Video
Over heating leading to resevior geting full of hot , no fans
CHECK YOUR FAN RELAY WHEN YOU STOP AFTER A DRIVE THE FAN SHOULD COME ON AUTOMATICALL TO COOL DOWN THE ENGINE ;;YOUR RELAY MAY BE BAD
Sep 16, 2009 | 1989 Acura Integra
Car amp
I believe the answer is both. The amp gets too hot and cuts off the circuitry and causes the amp to go into protection.
Your amp is only designed to run at 2 and 4 ohms. What you need to do is check out this site and run your subs at a 2 ohm load.
If your subs are dual voice. Run + to + to +, - to - to - in box. Run + and -, + and - to amplifier in stereo. Your amp won't shut off anymore.
Nov 08, 2006 | American Pro VS1405 Car Audio Amplifier
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
American Pro VS1405 Car Audio Amplifier Logo
262 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
