Question about ASUS VK222U 22" Monitor
How to reset ve228h asus monitor - ASUS VK222U 22" Monitor
Is the audio cable compatible with a Lenovo Computer?
Well the three contacts are 1-Headphones 2-Audio-IN 3-Line-IN,
If your expecting the sound to be heard on the speakers attached on your monitor then you will have to connect the 3.5mm pin on your monitor(Audio-In) and the other end to the headphones on your desktop.
Aug 22, 2014 | ASUS Ve228h-21.5in Lcd 1920x1080 Ve228h -...
PS3 asus mx279h hdmi black screen
When you turn on the PS3 hold the power button and it should do a couple of beeps this means it has reset the video output and should work :)
Jan 11, 2014 | ASUS Computers & Internet
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
Feb 07, 2011 | ASUS 19 Inch Sxga 1280X1024, 5MS,...
My computer monitor keeps saying auto adjust how do i fix this
Usually if the auto adjust is flickering intermittently you can attempt to reset the internal values to the factory settings. To do so: press the menu key on your monitor then choose factory reset. Press the menu button again then select all settings.
Jun 19, 2010 | ASUS VW192S Monitor
My Asus EN7200 GS stoped working, lines appeared in my monitor
you must be reset your bios put on jumper coms clear choice 2-3 then reset configure position again 1-2 then computer is ready activate built in agp
Thanks
Nov 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Asus z92r halfdead
try another monitor, monitor cable,or reset the bios. refer to owners manual for bios resetting procedure.
May 07, 2009 | Computers & Internet
Lcd monitor asus dont work after half our power on
Your monitor is set to turn off after one half hour, as a power saving measure, and you can reset the timing of this feature on the monitor, or in the power saving section of the display feature in your operating system under "displays"whether in a Mac OS (System Preferences) or in Windows in My Computer.
Reset the length of time you wish your monitor engaged in either or both.
Get back to me with further questions.
Mar 30, 2009 | ASUS PW201 20.1 inch LCD Monitor
ASUS VK222U 22" Monitor Logo
108 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
