Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My Badger 5 disposal won't turn on...
I checked the outlet that the disposal is plugged into and the outlet still works if I plug another appliance into it. I checked the red reset button on the bottom and pressed it so it went back "in" instead of "popped out". The disposal must be clogged because I can't get watet to pass through (unless the dishwasher is on, and then water fills UP the sink very quickly). I have the "food disposal wrench" that goes into the center hole on the bottom of the unit, however when I try to turn it, it will not budge at all. Finally, when I turn on the disposal, I hear the lighest hum. I have to almost place my ear to the disposal to hear it, so it's almost inaudible. I actually can't guarantee the hum even exists. I may just think I hear it. Any suggestions?
  • kellylynnb15 Jan 30, 2009
    Thank you for the tip. There does not appear to be anything wedging the blades when I look down into the sink. I can see that there are 2 sets of blades and they come up from the bottom and face up towards the ceiling....almost like spikes. The set on the right will turn just fine when I use my hand to turn it. The left set will not turn at all. It is completely stuck. Any suggestions on what to do from here??
    Thanks again, very much.
    President:
  • 2,559 Answers
Take the wooden handle from a plunger or broom and insert it in at an angle and pry in a circular pattern to free it up.
Also,if you can,Look inside and see if you can see anything that may be wedged in the blades.
Posted on Jan 27, 2009
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
If my Badger 5, 5/8hp disposal is leaking and needs to be replaced, do I need to replace it with the same exact model of can I replace it with a Badger 5 1/2hp disposal without having to replace the...
Generally speaking, a household disposal is a household disposal. The Badger is, IIRC, the same as the Kenmore, and several other brands. No, you won't have to change pipes. The pipes are the same. The only difference will be the power requirements.
Jul 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 just clicks when I try to turn it on. It is only 4 years old. We tried reset button, checked blades for something lodged in it, and unplugged and re plugged.
Use broom handle and see if blades turn freely.
If blades turn freely, and disposal makes clicking sound to indicate that you have power, and reset button is not tripped out, then disposal has gone bad.
If unit still looks new, then buy identical disposal from store, replace just the disposal body, and return defect in new box.
I wrote ez disposal replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When we switch on the garbage disposal, there's no sound at all..dead. Switched power cord to another outlet, plugged it in and automatically the motor turns on but the blades don't move. It doesn't...
If you plug it into the original outlet under the sink and flip the switch, nothing happens? No motor sound? And when you plug it into a different outlet, you can hear the motor, but the blades don't turn?
If this is the situation, I would guess that there's a problem with the insinkerator. Something stuck in it, or it's otherwise jammed. This could have tripped a breaker.
If the breaker failed or the circuit wasn't wired properly, this jammed condition could also have resulted in the wire at the switch or under-sink receptacle burning off of the terminals.
Turn off the circuit at the panel, double check that it's off, and remove the switch and the receptacle to see if the wires are still connected. If they've burned off, do not re-connect them. You should consult a licensed electrician to correct a hazardous situation.
Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator has power but does not grind garbage. have hit reset button and turned allen screw at bottom. now i dont get a hum from the motor.
Is it hardwired or does it plug into an outlet? If it plugs in, check the outlet for power. Is a circuit breaker tripped? How do you know it has power if it doesn't even hum?
Oct 14, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Disposal wont work
The reset button might be around the back, depending on which side the outlet is located on. It takes quite a good push to reset it.
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal won't work!
Check to see if the cutting plate is free and will turn-be careful and be sure no one can turn the unit on while you are trying to turn the cutting plate-it is located in the drain hole that the food goes down. If it is locked up, hardware stores sell a special tool to break it loose. It should not be too expensive. If the blade is free, the motor is probably burned out.
Feb 03, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
New Badger 5 insinkerator garbage disposal just installed 3/4 hp
I would definitely return this item to the store and get a new one. Not a good sign. good luck
Jan 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Switch will not turn on disposal
under the sink you will probably find an electrical outlet with the disposal cord plugged in. If so, plug another item into the outlet like a blow dryer to be sure you have power to the outlet. If you have no power the problem is a tripped breaker or a blown fuse. First check all of the plugs in the kitchen area including under the sink to determine if you have a ground fault circuit interrupter outlet. If you do, it may be tripped. If it is tripped simply reset it.
If you know you have power to the disposal then check to be sure no spoon or other hard object isn't in the disposal preventing it from operating. Use a flash light to check this. If there is no obstruction look on the case of the disposal for a reset button. good luck.
Jan 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,467 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
