Question about Leica Optics
Replacement battery cover for TTL Leica M6
Battery cover fell and was stamped on. Have the cover but plastic battery housing has broken off.
3 Suggested Answers
SOURCE: Bushnell Yardage Pro Compact 600
Mine broke too. Called busnell Customer Service and they sent me one.
Posted on Nov 03, 2008
  • 112 Answers
SOURCE: Battery cover, Bushnell Yardage Pro
1-800423-3537...gl...larry@reichinstruments.com
Posted on Apr 22, 2009
Need replacement battery doors for SUBX1
you can glue a little metal\ plastic sheet instad
Nov 09, 2013 | Sirius Boombox Antenna Jack Repair Service...
Tip
Replacing CR1620 lithium battery for Ultramax OB24
For consumers with the Brita Ultramax (OB24), the one with a digital memo. Here's how you can modify the battery housing for replacement.
Important: It is best to take pictures along the way so you know where the parts go during re-assembly.
I attached photos along on bottom of page for easy viewing.
1.) Remove the battery housing unit from the cover. It is easier if you unclip the small cover off from the larger (main) cover to do this. Carefully pry along the edges with a butter knife until the housing is raised up enough for you to pull if off with your fingers.
2.) Turn the housing upside-down (LCD reader faced down). Now carefully cut/slicing along the topside outer edges of the battery unit with a razor blade. Make sure it is cut evenly so that it can be reused as a 'cover'.
3.) After it is cut and exposed, tap the internals out of the clear plastic housing so you can get access to the battery. Stick something thin (such as the newly cut plastic cover) through the battery lever and push the CR1620 battery out. Replace battery, put everything back into its plastic housing.
4. After everything is reassembled with its new battery, put the (cut) plastic cover piece back, hold gently and wrap some clear packing tape such as 3M. You'll have to measure the tapes and cut them to fit. Secure the top portions with tape, then wrap along the sides to secure the rests.
on Oct 28, 2014 | Brita 35530 UltraMax Digital Water...
Cant plug battery in plug fell in computer
If the plastic is broken, your best bet is to tape the battery in so it does not fall out. I have done this a couple of times when I/customers could not afford new batteries.
Mar 22, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
Where is the battery on my 2006 Chevrolet Malibu located?
Your Malibu's battery should be located on the driver side underneath the plastic black cover that has a battery symbol stamped on it
Jan 05, 2011 | 2006 Chevrolet Malibu
Where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
The plastic piece that keeps the battery in place is broken.(F16059/4) is the watch
mcdevito75 here, This is a piece of plastic is used betwen the battery and the back cover of the watch as without the plastic there is a small gap between the battery and the back cover, meaning the battery could come loose in the watch even with the back cover on the watch, replace this plastic piece with some carefully folded Scotch Tape, cut and shape the Scotch tape to Approx. the same size and thicknesss of this piece of plastic or just by sight thick enough to keep the battery in place in the watch with the back cover on.
Aug 18, 2010 | Watches
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Battery cover for cds6300
the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
Oct 21, 2007 | RCA CDS6300 Digital Camera
Optics Logo
59 people viewed this question
Top Leica Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
woodzowl307
Tom Chichester
Are you a Leica Optic Expert? Answer questions, earn points and help others
