Question about Bosch Classixx WFO 2866 Front Load Washer
Bosch WFO 2042 springing
4 Suggested Answers
SOURCE: how to remove motor from
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
Posted on Aug 12, 2008
  • 6277 Answers
SOURCE: I have a bosch WFO
Sorry Maria but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 22, 2011
rex1998
SOURCE: How to disable beeps in Bosch wfo 2442 oe
please tell me somebody how to turn off spin for bosch WFO 2442?
Posted on Jul 08, 2012
Manual for a Bosch front washer WFO 2050
Link for Bosch website to download manual, you just need to input the product details apparently.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jun 16, 2012 | Bosch Washing Machines
Got a Bosch WFO 2460, drum stopped turning, replaced brushes and cleaned up the stator but it still wont work. When it stopped the first time it triped the Mains circuit breaker so i am wondering if there...
there is a thermal cut out located in the windings on the motor you may have o hunt for this it has a wire going in and n out, you could short it out as a quick test if motor running....
Apr 22, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
The fabric conditioner tray does not empty at all and remains in the dipenser at the end of the wash.
Bosch Exxcel WFO 2264 Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Dec 09, 2010 | Bosch Exxcel WFO 2264 Front Load Washer
Drum not turning
I would suspect worn brushes in the motor as being the cause of the problem here.
Check them, and if they are less than 3 or 4mm long, then they need replacing.
Jan 31, 2010 | Bosch Exxcel WFO 2864 Front Load Washer
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
May 29, 2009 | Bosch Washing Machines
Replacing door seal
If you have refitted the door seal correctly, then what you need to do is turn back the seal in on itself, and starting at the top start feeding the spring around the recessed lip at the rear of the seal, as you progress round stretch the spring as much as you can to get it all the way round the seal, you will find it easier to do, if you can have someone to hold the spring to stop it slipping off.
It is a fiddley job and you may find it slips off part way round, then you will just have to start again.
You will find it easier to fit , if you tilt the m/c back, this will give you more room to work in.
If you have got it on properly, then you should be able to pull on the seal with out it coming off.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Open Questions:
See all Bosch Classixx WFO 2866 Front Load Washer Questions
Bosch Classixx WFO 2866 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
