Question about EliteGroup nForce3-A Motherboard
I have a nforce 3 board, it starts with the windows didn't shut down correctly, you can try and start in safe or any other selection, it will start the xp page and go back to post and back to the select startup screen again, any suggestions?
  • 79 Answers
Go to your restore point and restore to the previous setting.
!: Go to Start
2: Accessories
3:System tools
4: system restore
Restore to a previous good date
Posted on Jan 27, 2009
  • 29 Answers
You don't mention if you can get into Safe Mode or not....If not then likely you will need to do a reinstall of XP. If that is the case then you probably want to do a "Re-install in Place" so you don't lose all your settings and such.
If you can get into Safe Mode, then I would start with a re-install of the video driver, as they tend to be the most problematic if they have become corrupted for some reason.
In device manager, under Display adapters, highlight the adapter shown and delete it. Reboot your PC and windows "should" reinstall your video driver, or at-least the standard VGA driver that XP defaults to in such cases.
Another option to look at is within the Boot Menu, select "Last Known Good Configuration that worked"....and see if that will correct your problem.
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
How do i get my computer to run in normal mode again? and how do I get rid of the google chrome because this problem didn't start until i downloaded it into my computer.
Once Safe Mode comes up, click Start/Programs/Accessories/System Tools/System Restore and select a Restore Point (date and time) that is before you downloaded and installed Google Chrome.
I seriously doubt that Google Chrome is your problem. Chrome is among the top tier as far as browsers go.
I think you've got a windows system file or boot file issue.
Apr 15, 2012 | Gateway NMZ-500SE Notebook
User mode window (for adjusting the contrast, brightness etc) appears again again automatically.
First off... I would Re-Start your computer...OR...Shut down manually... to see if this fixes your problem. It's possible your computer didn't accept the changed setting? But...what you are experiencing is a Corrupt File, which will need to be removed!
Not sure exactly what you did? Where you trying to adjust the contrast, brightness, etc,.?
If you went through your Desktop to adjust these settings, always make sure you select APPLY and OK..
If you went through your System to Change your Resloution, you may have a Conflict with your chipset or even Malfunctioned it?
If re-starting your computer didn't fix your problem, than shut your computer down again!
Upon,..Re-booting...This time hold the Control Key down, so you can get into SAFE MODE!
I would then do a SYSTEM RESTORE under (SAFE MODE) and Restore your computer back to an earlier period that your computer was working correctly! Even, if you cleared the problem on the first step provided! Just type in the search box in your Control Panel System Restore! Or you can type in at the START Button...System Restore!
Also, while in SAFE Mode...go to your Device Drivers in your Device Manager and check for any setting that have a yellow symbol next to them...Click on each one and Update the Drivers!
Always, make sure...you Re-Start your computer after doing any changes...!
If you need further assistance, please don't hesistate to reply back to me! I'll be happy to help you!
Kind Regards!
Martie
Sep 10, 2011 | Dell E773C 17" CRT Monitor
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
PC boots but no video display. worked fine last night. i was reading on my PC Kindle ap. fell asleep and when i woke the screen was asleep. i shut the unit down. didn't think anything of it. Now...
look sir
first thing you try to boot on safe mood (to make sure that the problem is about operating system windows or the problem could be simply that the display card driver has crashed
turn on your computer
press f8 repeatably you will show a list to choose from like
1 - start windows normally
2 -last know good config .....
- safe mood
press the number crossponds to safe mood the enter
wait until the machine boots
it will look odd the windows don`t worry
go to start menu then select accessories ---- system tools -- system restore
choose yesterday cheek point
May 22, 2011 | Acer Aspire 77415137 Core i3350M...
DELL STUDIO 1737, WITH WIN 7, WILL REBOOT AT SHUTDOWN.\r\nIT SHUTSDOWN FOR ABOUT 3 SECONDS, THEN REBOOTS TO A BLACK SCREEN WITH: "WINDOWS DID NOT SHUT DOWN PROPERLY, SELECT ONE OF THE FOLLOWING:" Start...
operating system issue try to repair os or make a clean new os installation (make backup before you go for clean instillation...
best try to repair and restore....
thanks
Aug 18, 2017 | Dell Studio 1737 Laptop
Accer laptop shut down after window xp logo & recovery disk misplace .kindly advise the next step to start the windows
You need to find out why its shutting down. Try starting in safe mode. When pc starts keep pressing F8 and wait for list to come then select safe mode. Then scan your pc with spybot search and destroy...Hope this helps...
Nov 17, 2009 | Computers & Internet
Laptop won't startup properly
Friend that problem if cause of not shutting down properly.just select start safe mode as it recovers it will restore late back to the proper one
Jun 05, 2009 | Tablets & eReaders
New builded pc wont install, system is schut down.
Hi Henrick,
Are you using the correct spec R.A.M.? or is it faulty.
I relate to your problem and all looks fine apart from memory.
Don't rule out the possibility of a Mother Board fault? I have had similar& severe grief in the past, tried all routes and replaced loads only to find sata circuit connection dry joint/ un soldered. (So New Motherboard under warranty)
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 14, 2009 | Ultra Products Ultra Defender Intel Gaming...
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
EliteGroup nForce3-A Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
